Disk brake conversion
chevydude
arizona
hunt
k20
Hello i have a 1985 gm 14 bolt.
I want to do a disc brake conversion for it.
If you have the right brackets can you use the disc roters and calipers.
I have the full set so that is what i wanted to do.
Thanks just wondering if anyone knows.
chevydude
arizona
hunt
k20
I have dana 60 roters and calipers
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Cant use Dana 60 calipers & rotors, calipers are made way different. You'll need 3/4 ton truck front rotors and calipers. I guess it really depends on the brackets you use but all of em I've seen is for 3/4 ton front rotors/calipers. Got a link or pic of what brackets you're going with? I will probably be able to tell by looking at them.
chevydude
arizona
hunt
k20
Well that is good to because we have loads of spare parts and i have 3/4 ton calipers and roters. Thanks for help.
nvrenuf
Mobile, Al.
You can do rear disc with d60 parts pretty easily, you just need to fab flanges to weld onto the axle housing that you can then bolt the d60 caliper brackets to.
chevydude
arizona
hunt
k20
Ok thanks
I was digging thru the stash and i have 3/4 ton calipers and im not sure if the roter is a dana 60 or 3/4 ton did 3/4 ton come in 8 lug
Thanks
nvrenuf
Mobile, Al.
Ok thanks
Thanks
For square bodies, ALL 3/4 tons were 8 lug however the rotors are different between 3/4 and 1 tons. GM 1 ton rotors are 13" in dia and 1.5" thick (new).
chevydude
arizona
hunt
k20
Cool I will check thanks for the info.
chevydude
arizona
hunt
k20
Hello again I just checked it measure 12 in half in diameter and 1.5 in thickness
nvrenuf
Mobile, Al.
I don't know the measurements on a 3/4 ton, been a loooong time since I messed with one.
chevydude
arizona
hunt
k20
Thanks anyway you have been loads of help.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
14 bolt brackets cheap i have these for my crew cab
http://diy4x.com/cart/index.php?route=product/product&path=37&product_id=35
disc brakes have 2 pounds residual pressure and drum brakes have 10 pounds so you will need a proportioning valve
i just bought one of these look more on ebay i found some cheaper
http://www.ebay.com/itm/gm-car-prop...Parts_Accessories&hash=item2a25213ee4&vxp=mtr
and i got these brake lines i am going to mount the tab to the spring perch and run hard lines from the tee to them
http://www.ebay.com/itm/Allstar-ALL...t-/330819258839?forcev4exp=true&forceRpt=true
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i have not found a good master cylinder for disc front/rear yet so i have no advice on that yet
but i can say those brackets from diy4x are awsome. i have used the first design they had (used spacers) and the design in that link it is built very well.
i have not installed it yet but i am about to as soon as my other parts show up.
nvrenuf
Mobile, Al.
I used a master cylinder from a 99 C3500 on my K5 and it works great. The 99 C3500 is a 4 wheel disc, vacuum booster applicaion.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
aaron06
