- Jan 14, 2024
- Cumberland, NJ
- A
- K10
So, let me start off by saying I did this to my self by installing a Vintage USA dash in my 1985 K10 Silverado shortbed during a full restoration. Mistake, nothing but problems. This is NOT a plug and play upgrade. Expect to spend countless hours with whatever wiring diagram you can find on line, a test light, wire cutters a soldering iron and everything else you would need to destroy a perfectly good dash wiring set up. I am on the 4th tachometer (sending this one back Monday) and I think I am going to put wing nuts on the dash pad to save me time for next time.
Problem: when the marker or headlights are on, I am getting a significant glow from the blinker indicators on the dash. I have tapped the dark blue and light blue for left and right, but I am getting a power bleed somewhere. I can’t find a wiring diagram that is complete enough to track the entire blinker system, but the only place I can see the parking system crossing with the blinkers is at the bulb (yes I have LED aftermarket 1157s). I don’t think anything is pulling a ground. I feel like there is a relay or something that is not grounded now that I have pulled the original that I don’t know about.
