Crate engine swap advise please?
73 C10
California
Scott
Try limiting it to 8- 10 and see what that does.
Sent from my LGLS991 using Tapatalk
I will do that next.
Keep in mind that in post 182, I said did not report the problem 'till the end of the trip. I seemed fine when I left, I think.
Also my set up will be
8* base, 20-22* va, 20* mechanical, 98, 95, 7037, 5" springs. Only changing one thing. Base to 8*.
Back in a few...
350runner
tx
Ceasar
Do this test without vacuum advance
73 C10
California
Scott
OK, so I re-read this and maybe you are reading the difference. I don't know what light you are using.
If you are reading the difference, that is too much VA.
The paperwork specs 10* on the cam, which you reminded me is 20* on the crank earlier. I new that and I agreed. That's what I measured. That's why when you suggested the 15* it made sense, and still does. The 2:1 thing. I thought we agreed. I thought we discussed this earlier.
I like to talk in one unit and since base is in crankshaft degrees, staying in crankshaft units makes sense to me. That's why my count ends up in the 50's total.
350runner
tx
Ceasar
What cam are you running?
rich weyand
Bloomington Indiana
Rich
Understood. What I don't understand is whether the light is showing you difference (VA only) or total (VA + base) the way you are using it.
15* on the crank is what you want.
rich weyand
Bloomington Indiana
Rich
And with 19" of vacuum, you want the 8" springs.
rich weyand
Bloomington Indiana
Rich
OK, but it's gonna run lean unless you have your foot into it enough for those springs to win against the vacuum and pop up. Running lean is not good. Especially when you are already trying to figure out a knocking problem.
73 C10
California
Scott
I admit. I may be using and interpreting the light wrong.
73 C10
California
Scott
Gotcha. I'll do it next.
350runner
tx
Ceasar
What paper work are you speaking of?
73 C10
California
Scott
So now. I started by checking what I was at pre-drive. I unplugged the va and pluged the carb port. I zeroed the light. I read the timing on the tab at 10* @ 580 RPM. I adjusted the light 'till the TDC mark on the balancer lined up with the 0* on the tab and I had adjusted the light 12* from zero on the light. 2* difference. So go with what you want but there is an offset and I've been stating the light adjustment numbers so far. I set the light to 8 from 12 and set the distributor where the TDC on the balancer lined up with the 0* on the tab. I think that would be 8* BTDC @ 680 RPM. And would read 6* on the tab but I admit , I don't think I stopped to look for comparison.
I took a a spin with the va off and port plugged. It bogged taking off from a more labored sounding idle. Pulling out light footed was OK, but hammer down up to 45 was the rattling valve train sound. It lessens when letting of a bit with the foot.
Almost the same with the va plugged in. Bogged taking off.
350runner
tx
Ceasar
I bet my last dollar your just experiencing rattling rockers...
73 C10
California
Scott
GRat
