Correct transmission
73c20jim
Sierra Vista, AZ
C20 2WD Custom Deluxe
350 CID 195/260 HP Goodwrench crate
Is a TH350 or a TH400 correct for a 73 C20 with max payload. 14 bolt FF rear.
Big Chip
Michigan
Kevin
C35
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Back then it may have depended on the mood along the assembly line that day or many other things. Some times there was no rhyme or reason for what went into what. Most of the stuff that came into our dealership was kinda what you would figure,350 V-8 and Turbo 350 trans or 454's and 400's(2WD)
73c20jim
Sierra Vista, AZ
The Heritage says a three speed forward automatic transmission.
Where do you see it says otherwise.
Big Chip
Michigan
Kevin
C35
M49 is TH350
M40 is TH400
Of course that’s only helpful if you have Your SPID.
73c20jim
Sierra Vista, AZ
I see M49 in Heritage. TH350.
Big Chip
Michigan
Kevin
C35
Even when I’m wrong I’m right I guess. All I had to do was read my own post.
samelthecamel19
