Correct power steering pump
Dave M
Banned
Australia
Dave
I have a 1976 C10 pickup, with a 454 fitted with power steering and factory a/c. I believe it has the wrong power steering pump fitted to it, as the rear of the pump body hits the a/c compressor bracket, leaving very little belt adjustment. It is the square shouldered type pump body. I was hoping someone could post a pic of the correct pump. Thanks in advance.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
Why cant you just swap over to one from a newer model with AC?
Should be the same fitting for the pressure line.
I had the huge ac compressor above this, but I ditch ac in all my stuff.
But it all fit just fine.
Hope this helps, 88 Suburban V20.
Welcome!
dvdswan
Port Orchard, WA
Dave
Welcome to the site. IIRC all the pumps were the same except for hydraboost. If possible take some pics of different angles of the PS pump and compressor and brackets.
Dave M
Banned
Australia
Dave
Dave M
Banned
Australia
Dave
Ok , here is what l have.!
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
Missing the top bracket, atleast the bolts.
Definitely different from mine bracket wise. But no way should it be that tight on the water pump.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
If I am totally wrong above. The two sqaures atleast go together somehow(says my 3 year old self). Lol
1985c20
Torrington, CT
Chuck
disclaimer: I don't know a lot about the v belt setups on these trucks so take this advice as is. I think your power steering pump should be spaced out so the belt from the water pump/crank rides on the inner sheave of the power steering pump and then the ac compressor gets driven off the outer sheave. If you space it out like that it might solve the clearance problems to the ac compressor as well. The square holes should be holes for tensioning. You insert a 1/2 or 3/8 ratchet and can hold the tension while tightening the mounting bolts.
Craig 85
Nashville, TN
454/TH-400/NP205
I'm going to guess you should probably have the bracket similar to the one in post #3. You have the same A/C bracket I have on my 454, but my K30 has hydroboost with a remote reservoir.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
I know nothing about hydroboost.
Glad you saw that.
My bracket is incomplete, I cut off the ac extension part.
Makes sense now that he just has the completely wrong stuff.
Craig 85
Nashville, TN
454/TH-400/NP205
I started looking at some images of 70's 454 trucks and remembered this pump style. I recall some of my 70's square bodies having it. Maybe this is narrower neck is what you need to clear the bracket. Classic Parts sells this one for big block 75-79 trucks. $65
https://www.classicindustries.com/product/1978/chevrolet/truck/parts/ps6999.html
I don't know if you have Napa Auto Parts there, but they carry a rebuilt one for $52. P/N PS 381266.
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
+1
My V-belt setup is exactly as described here but I have a 350. Not sure if the 454 would be setup the same way or not.
dvdswan
Port Orchard, WA
Dave
You may have the wrong bracket for the PS. The cap should be near level. Yours look like its at a 30* angle.
Original
