Coolant leak after replacing heads
chris44nala
Limestone County Alabama
GMC Sierra
Hi,
So, I bought some heads for my 78 GMC and finally got the thing back together. All seemed well at initial startup. Oil pressure, good. Coolant temp good. Then my worst fears were realized. Billowing white smoke after a short drive. Got it home after fumigating the neighborhood and parked it.
The question is what is the best way to determine where the leak is? Also, is it possible that it is an intake manifold gasket problem?
Thanks for the help,
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Water in oil may be an intake manifold problem. But water in the combustion chamber points to head gasket or cracked head.
Rusty Nail
Rusty
350sbc
You performed a final tightening during assembly? I would check the torque wrench before I started killing new gaskets. :killer:
Absent sealer around the coolant passages is a big no-no :nono:
If those checks fail..that's not promising.
Good Luck.
Hope this helps!
Rickf
Grafton NH
1974, 1954 & a 1937
Air bubbles in the radiator is another indication of head gasket problems.
boarder421
