Complete Rebuild?
Che757
Tampa
Lee
Hello all, I'm new to the site and after posting my intro here is my question. I bought my 83 c10 about a year ago and the old owner stated he had the transmission rebuilt. I even have a receipt for Raybestos parts,so not sure if he did it himself or not. Here is my delima, about 3 months ago the tranny started to leak, to me no biggie as I only drive this thing on th weekends and I pretty busy. I just got around to look under the truck and this "seal" I think is loose between the tranny and the shaft. Now I'm no mechanic but other than the leak the tranny shifts perfectly as long as there is fluid. It's a 700r4. Am I looking at a complete rebuild or just a repair. I don't want to get taken at a transmission shop. The rest of the tranny looks new
marks86
Latham, NY
Mark
12v Cummins
I would start buy replacing seal
Che757
Tampa
Lee
Thanks marks86, do you know if the whole tranny needs to be dropped in order to get that done?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Just the driveshaft needs to be pulled. You could probably pop that seal back in with a mallet but since seals are cheap, I'd replace it to be on the safe side.
Che757
Tampa
Lee
Thanks Retro,
I was nervous because I thought it was the rear end initially but the fluid was running down the shaft dripping off the rear end
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Thats a super easy fix. :cheers:
350runner
tx
Ceasar
If the fluid never got low enough to cause slippage or damage it won't need a rebuild. How ever you will need to remove the drive shaft to replace it. Very Simple
MadOgre
NA
NA
NA
NA
NA
The guy probably lubed it to slide it in. lol make sure the transmission and new seal are nice and clean and dry before installing them. Once the seal is installed then you can lube up the rubber lip with some ATF before reinstalling the drive shaft
Extension Housing Oil Seal
GM P/N 8673526
Che757
Tampa
Lee
I finally got around to getting this done...No more Trans fluid on the garage floor. Thanks all @chengny thanks for the part number.
chubhub6969
