Coil overs vs. Regular shocks
78C10BigTen
pennsylvannia
C10 BIG TEN
So looking for new front shocks i hopped on rockauto just because they have the discount code. Found that shocks are way cheaper on there, not sure of the quality but it raised a question.... are normal shocks better or are coil overs? Im not sure as ive never had coilovers.
WFO
Texas Panhandle
I'd go with regular shocks. Shock mounts aren't really meant to carry the load.
4WDKC
Southern Florida
Kacy
depends on the suspension setup, the lower shock mount on a 2wd uses the same metal to support the weight as the coil overs, What i think he meant was shocks with spring helpers like
not
  • Like
Reactions: WFO
78C10BigTen
pennsylvannia
C10 BIG TEN
not
My bad.... yes i mean spring helpers. I was unaware of a differance.
  • Like
Reactions: WFO
78C10BigTen
pennsylvannia
C10 BIG TEN
Would the coil overs help lift up the front?
4WDKC
Southern Florida
Kacy
they can but your limited to length of stock suspension unless you change it out. On a 2wd you could buy different spindles to raise it and keep the same ride quality, 4wd requires redesigning your suspension to eliminate the leaf springs and go to a four link setup. Keep in mind they arent cheap, the pair I bought were $400, the double adjustable ones are $700 for the pair.
78C10BigTen
pennsylvannia
C10 BIG TEN
Im looking to actually get mine to sit level and maybe fit 16's under the front. I know my shocks are shot and probably my coils but im looking for a cheaper easier way to get her nose up.
4WDKC
Southern Florida
Kacy
new springs are like $60 do a search find what spring rate people are using in these trucks for desired result like handling and google moog spring rate chart and springs to fit.
$60 springs
$100 shocks
spindles ?
WFO
Texas Panhandle
I put big block coil springs on my 84 GMC back in 86. It leveled it up, and took out a lot of roll over in the corners. It was a long bed.
78C10BigTen
pennsylvannia
C10 BIG TEN
Does it make the ride quality alot harder, stiffer? I like my soft bouncin truck but want it to stand taller in the front. Are 3/4 ton coils interchangeable into a c10?
WFO
Texas Panhandle
That was over 30 years ago, but I remember that it rode better. I switched to gas shocks at the same time.
I'm not sure if 3/4 ton springs will mount, but I think they would be way too much.
I'm sure there's more spring rate options out there now days.
78C10BigTen
pennsylvannia
C10 BIG TEN
I think i confused bb springs with 3/4 tons....
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
This is the hot damn setup for 2x
deviant
Augusta, GA
C10 Bonanza
not
These are just non-shock adjustable coilovers (top) and shock adjustable coilovers (bottom). Major benefits are less rollover, stiffer ride (if you're looking for that), increased towing capacity (with rear coilovers) and even extra load capacity. How much depends on spring rate. Shock adjustable coilovers benefit you more when you're running something on road and on track, so you stiffen the ride for track and soften it for daily cruising. I don't really see the benefit for a truck for the extra money, except maybe on an extreme drop where you want to help prevent it from bottoming out. Which in that case, you can go with heavier rated progressive springs in your control arms and/or leaf springs. Any gain in ride height will only come from a longer shock, but what you will get is less sag from a coilover. When you lower a truck and account for 5", but it sags to 6", then a coilover can put you back at 5". Me personally, I run a stiffer progressive spring in the control arms and good damping non-coilover shocks on all four corners and sway bars to help on road handling.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Can you please describe what you mean as 'control arms'? What may I ask are control arms? Sorry I though square body 2x2 trucks had A-frames so I'm confused.
I've certainly never heard of progressive springs for the front of these trucks...
Ls85c10man
