chevy 350 brand new rebuilt motor weird noise !! HELP!!!!
ruedger455
three rivers , mi
kimber
k2500 grande sierra
Hey guys I just had my motor is my 77gmc rebuilt. Well it runs great, but when I get on it and get up in rpms about 3k. It sounds like a rattle snake rattle but really fast. Almost like a sprinkler. Thats the best way to describe it. But its loud like it drowns out the exhaust. Im pretty irritated at this but am not wanting to tear into it as I dont have the money to replace parts right now but its my daily driver. Could you guys help me out? Just looking to get some idea of what it could be.
350runner
tx
Ceasar
Detonation from the sounds of it. Back down the timing. It'd that's what it is you need to reduce the amount of mechanical advance
ruedger455
three rivers , mi
kimber
k2500 grande sierra
It also at idle has that noise like a diesel like that popping rattle hard to describe.
I am hearing the same noise (to a much lesser degree) from my truck's power plant. Mine is not yet what you'd call a daily driver - it's still a work in progress - so I have not really tried to locate the source.
This is what I have noticed:
It sounds like a metal-to-metal interference issue.
It only cranks up when I apply a sudden heavy load to the motor.
It tracks along with engine speed while it is audible.
It immediately ceases when the load is dropped.
The first thing that comes to mind is a flexplate bolting problem - but the engine has basically no miles on it since rebuild. The T/C to F/P bolts were properly torqued and made up with blue Loctite. For those reasons, I am not inclined to go that way.
But you might want to pull the cover and recheck your bolting.
My next thought was some kind of interference in the fan/shroud area. But that doesn't seem right either. The shroud is plastic and would quickly wear away at the point of contact - I think.
Also, I seem to recall hearing this noise before on other similar trucks. To deal with it, I just stopped hooking the truck up so quickly. It went away and I soon forgot about it.
I would look around the engine compartment and try to find something that could come into contact with a rotating external engine component. Remember, when the motor is quickly and heavily loaded, the entire assembly reacts to internal torque and twists slightly along it's axial center line (this is true even if your mounts are good). Look for shiny spots, loose components, etc.
If I can find the source of my rattle, I'll report back. But don't hold your breath.
You don't think you might just have an exhaust leak at the manifold do you?
Dump some MMO down the carb, rev the engine and look for white smoke.
Really should look at your flex to converter bolts.
ruedger455
three rivers , mi
kimber
k2500 grande sierra
Ok well I just talked to the guy that built my motor and he said the compression is 9.7:1 and ive been running it on 87 octane and he said I should be using 93. So im gonna try that after work to see what happens ill let you guys know.
350runner
tx
Ceasar
Back down that timing till you get that 87 out of there or at least keep away from wot
ruedger455
three rivers , mi
kimber
k2500 grande sierra
My gas tank is on E so today im gonna fill er up with 93 and if that doesnt work im gonna bump the timing down.
350runner
tx
Ceasar
Awesome!
ruedger455
three rivers , mi
kimber
k2500 grande sierra
Well changing gas hasnt worked yet. But I went to bump down the timing and low and behold my distributor was loose. So im gonna set the timing at 10° initial and see what happens.
350runner
tx
Ceasar
Yup
ruedger455
three rivers , mi
kimber
k2500 grande sierra
Well timing is set at 10°btdc initial. And it still does it! Could this just be an exhaust leak?
350runner
tx
Ceasar
Yup check around glad you found your distributor was loose. Check the heads and collector gaskets
MadOgre
NA
NA
NA
NA
NA
doesn't sound like loose valve lash ?
Shak379
