Catalytic converters
mcpaddleboat
Alabama
Wilson
GMC Sierra k1500
350 tbi
06 Chevy 1500 z71 with the 5.3, it’s my friends truck and he just cut the cats out but isn’t goin to replace them with anything for a few days. So he’s just runnin with about a foot or so of straight pipe after the exhaust manifold. I’m worried he might burn a valve. He says the truck runs better with the cats off so should we Try hollowing the cats out and welding them back. Or trashing the cats all together and weld some pipe and call it a day. Open to all suggestions
Shoulda thrown a code too. He could finish off the exhaust without Cats, but may need a tune to tune the Cats out and delete. I wonder what the O2 sensors are thinking? :shrug:
mcpaddleboat
Alabama
Wilson
GMC Sierra k1500
350 tbi
Thanks I’ll get started on Welding some pipe in place. He has a programmer so I’ll look into running a tune. You don’t think he’ll burn a valve in the mean time running with open pipe that close to the block like that?
Snoots
Roger
Jimmy Sierra
350 w/203
I am not going to recommend anything illegal, but for the short term, he can take 2 large rags and stuff one in each pipe when he gets to where he's going. Then take them out when he's ready to go elsewhere.
That'll keep cool/cold air from rushing back into the pipes.
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
The ECM can be re flashed to 02 delete, depending on what kind of DMV inspection is required should be considered. Re flashing makes the ECM think the o2 sensors are happy.
77 K20
Montana
K20 5" lift
HT383 fuel injected
I wouldn't hollow out the cats. I've done that on older vehicles and often it makes the exhaust sound "funny". The exhaust noise then just bounces around in the empty metal box that used to be the cat- and turns it into an echo chamber that can be heard.
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
I would just put some shorty headers on it if deleting the cats is the plan. A muffler shop can easily fab up a real duel exhaust system for it.
436'd skylark
VT
Joe
2500HD
Durajunk
He won't hurt any valves like that. That's an old wives tale. Every race car out there is running open headers..
Very little to be gained by cutting the cats out. Just a harder time trying to pass inspection really. As mentioned the turbulence created by the air bouncing around the empty cat is hurting more than the functioning cat.
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
Some states don't require an emissions test, just a safety inspection. Lights, brakes, ect. I was going to buy a beautiful 96 1500 short bed from NJ, but the cats and o2 sensors were removed. That wouldn't fly in NY. One emission code here is a failure.
mcpaddleboat
Alabama
Wilson
GMC Sierra k1500
350 tbi
Yea an emissions test in not a problem we’re in Alabama lol. When we cut them out one of the cats didn’t even have a screen in it. And the other was just super clogged. It’s throwin the low circuit voltage code today which is normal. The truck runs a lot better without them in but I was just worried about a valve thanks all
Derrick
near Milwaukee, Wisconsin
Derrick
Now, of course, this is for "offroad use only" but I would put exhaust pipe were the cats were and for the light on the dash try this
Same in Cali. Check Engine or Service Engine Soon light on = FAIL. However, if it can pass the visual, no codes, and pass the sniffer test, then you're good to go. They don't ask or check the Converters to see if they work. If they are present, then PASS. But you're engine better be running pretty clean to pass the tailpipe sniffer without Cats.
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
Wow, still sniffer emissions in California?
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
Hotrod, how is the sniffer inspection done, the put the car on the treadmill? N.Y. stopped that years ago.
Now you're about to catch me in a lie. I haven't smogged cars in Cali since 1990 when I moved out of Cali. So I'm far from up to date on their current laws and procedures.
mick84
