carb to tbi?
thebrad
Hillsboro OR
Brad
So after reading about the limitations of carbs for wheelin and their obvious efficiency shortfalls I was wondering how involved/practical or would be to do a conversion? I know fuel injection requires way higher fuel pressure and a pretty intense revamp of the fuel system for most conversions. All the write ups I've read about doing an efi conversion have been for 4 cyl multi port injection like megasquirt or other stand alone setups. Can someone enlighten me?
Look around here a bit, it's been covered a few times. TBI doesn't have as high of a fuel pressure as a multi port setup, so you can use most of your current fuel system if desired. You can run an inline fuel pump, back near the tank.
reddouble86
Boise,Idaho
Brock
C30 Silverado Camper Special Dually
454/SM465
Howell fuel injection makes a kit for the swap.
thebrad
Hillsboro OR
Brad
I'll do some digging on here. I made it through 2 pages of threads searching "tbi conversion". That Howell kit would be nice but its a little pricey. I could just buy a parts car for that much.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
search ebay...good deals to be had.
you should also look around in the bone yards, if you find an 87 to 92 tbi truck with the tbi, manifold, distributor, computer and harness, i can walk you through the swap.
thebrad
Hillsboro OR
Brad
Do you actually need the dizzy? It'd be a SERIOUS downgrade for me to swap out mine... I've got really nice ignition setup and I'd hate to see it go lol.
Jims86
Patterson,Ca
5.7 TBI
No, you can make it work, but you would need to lock the mechanical advance, and the vacuum advance would go too. The timing is controlled by the ECM.
Still no biggy.
Have you looked into Holly's truck avenger...just sayin, if you like your setup the way it is now power wise, and bogging out is the only issue, i have heard a lot of good stuff about that carb.
mick84
