Carb recommendation 1974 Cheyenne 454CI
frankthetank1963
Cleveland
Frank
Cheyenne
454CI
New here! Just wondering what you all have had good luck with when replacing the original carb (rochester I believe) with aftermarket Edelbrock, Holley etc...
Can you provide part# or link? I seem to be having difficulty landing on the exact carb for my application using vehicle lookup on certain supplier sites.
Can you tell me why you prefer the carb that you suggest to me?
Thank You.
nvrenuf
Mobile, Al.
Purpose - mpg’s, performance, etc? Is a choke for cold starts important?
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
While I ran a q-jet for years, it was more of a mystery to me. I have had Hollies on almost every engine I run, highly tunable, I ran a 750 on my 454, ran great, and while it did take some tome to dial it in, in was instant gratification withn the peddle to the metal. This is my new carb for the 489, quick fuel, and the 750 Holley
malibuman402
Navy
nc
Larry
C10 Silverado
BB 427 as of July 2023
Welcome. "ATM" go to there website and fill in the request form. they will reply in a day or two with size and cost.
The Edelbrock AVS-2 (not the old 1406) get a lot of positive reviews for a simple replacement carburetor. Like many Edelbrocks they are set up for economy and tend to run a little lean out of the box, but the throttle responsiveness seems to be quite good. Holley is usually more tunable, but I don't know how much you want to learn about the subject.
One challenge with the Edelbrock and Holley carbs is that they are square bore, so a stock Quadrajet intake manifold has to be adapted. There are simple bolt-on adapters, and aftermarket throttle brackets that work fine, but it adds cost to the swap. Due to the design of Edelbrock fuel feed (and maybe Holley), you may also have difficulty with a stock air cleaner working unless you install a spacer.
legend57
San Jose, CA
Rob
I had success with National Carburetors. I bolted it on, adjusted the idle, and it runs great.
Here's one for your 1974 454: Hard to beat $270
As others have stated, the only other thing I did was add the electric choke.
Sad Sack
Nebraska
Goober
C15
I put one of those Holly spread bores on my 71 Cheyenne.
It was $100 new in 1980.
I too bought one new in later 70s for my 71 Camaro 350, think it ran me more than that. Loved it, only diff was it had mechanical secondaries and no electric choke. Was an older List 6210 model. New ones today are plug and play and have electric chokes.
ls1Miguel
