Cancelling cam
73c20jim
Tombstone, AZ
It seems that there are two cancelling cams. One tilt, one non. I have a green cam and I thing I need the white one Dorman 83232 for my non-tilt.
All springs and stuff all look good, so I'm guessing I got the wrong one cause it cancels the left but not the right signal.
Comments????
The green one is correct from what I remember. If you had one for a tilt column, I don't think you could have even got it put together. I know for sure a non-tilt cam will not fit in a tilt column.
73c20jim
Tombstone, AZ
Gonna get the white one and see what happens.
73c20jim
Tombstone, AZ
Both non returning right directional signal lever and horn beeps with lifting lever are fixed. One solution fixed both.
If you voted that @bucket was right about the green cam, you were correct. That boy ain't been wrong yet.
If you voted that 73c20jim (that's me), screwed the pooch on installation, you would be right again.
It seems that you have to use the correct screws to mount the directional signal to the column AND that those wrong screws did not correctly secure the directional signal to the column, you would be correct again.
Who knew? They should have instructions for this stuff.
Thanks again @bucket .
I'm glad you got it figured out, I knew you would!
Oh and the fuel pump came yesterday too. Thanks again!
73c20jim
Tombstone, AZ
Very welcome.
ruggedly
