Cab trim removal ?
Reno81K20
Reno, Nevada
1981 & 1985
K-20 & C-20
350 4Spd & 350 Automatic
Ok, I have an 85 C20 Silverado with the band that runs the width of the back of the cab, It's really in good shape with few dings and scuffs in it.
My question is how does one go about removing it without destroying it?
I haven't tried taking it off yet, but really want to so I can try and clean it up and remove some of the small dings. Then go over the whole thing with some steel wool. Then I want to replicate it onto the 81 that's sitting next to it. Any suggestions ??
Pictures are always welcomed.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
The trim on the cab corners have a small nut, you'll find it if you reach your hand up the rear pillar, once its off just pull on it. The long piece that runs the width of the cab has a series of plastic slide clips. Just grab one end at either side of truck, and pull/slide it out. If its never been removed, it probably has dirt and debris in it, and you might have to play with it to loosen it up. Depending on how deteriorated the clips are, some or none will break these little ear thingy's they have. But in the end, it should slide right out, and slide right in
firebane
Calgary, AB
Curtis
Remove 2 pieces from the side of the cab from the inside; I think its 2 10mm nuts.
Once the side pieces are off the band just slides off.
Reno81K20
Reno, Nevada
1981 & 1985
K-20 & C-20
:) Thanks everyone. I will try and pull it off later. I bought a body hammer kit from Harbor Freight a few days ago and thought it would be the perfect thing to test my patience with. Just hope it all goes well.
Thx again .
Reno81K20
Reno, Nevada
1981 & 1985
K-20 & C-20
Thanks so much for the link. I saved it and will try it for both my cab trim and tailgate trim.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
There are some metal prong thingys that hold the plastic clips behind the aluminum trim along the back of the cab. I had a really tough time removing the dings from my trim and I have done a lot of bodywork throughout the years....so I opted to ditch them entirely. Now they all just sit on a shelf. When reinstalling the aluminum trim, LMC Truck has the plastic clips. The original clips break really easy after being there 30 plus years. If you aren't happy with the refurbished trim pieces, LMC Truck also has those as well....just an fyi.
wilson79
