Cab Mount Bolts/Captured Nut Loose
Ken B
indiana
ken
I am looking for advice on how to deal with a loose captured nut on passenger rear of cab. Anyone been down this road before me? I do not want to tear everything else loose until I figure this one out.
Joshua Keith
Memphis
Joshua
Drill a hole and tack weld the nut through the hole? You’re talking about the cab bolt/nut correct?
Ken B
indiana
ken
yes cab mount bolt i can feel the nut slipping when I turn the bolt from below.
I have heard about cutting a sqare hole in floor of cab, on the "shelf" behind the seat.
Doppleganger
OH-MI: Just like it sounds
He repairs one in this vid.
Joshua Keith
Memphis
Joshua
Looks like he decided to cut it open.
Ken B
indiana
ken
i actually watched some of those brothers videos.
dsteelejr
Hudson, WY
Happened to me. Had to cut open from the inside of the cab behind the seat and weld the nut back in place.
Ken B
indiana
ken
i hate to cut good metal but no other way .....
Ken B
indiana
ken
OK next question....so cab removal with on a 4sp 4wd. the 4wd shift lever will not be a problem but I think I will have to remove the trans gear shift to lift cab , whats the easiest way?
Ken B
indiana
ken
I am removing the cab to put on another frame. Just looking for an easy way to take gear shift off so I do not have to lift cab up and off of long gear shift
hoagster
California
K10, 1500
5.3l
Push it down and twist, it will pull right out!
Ken B
indiana
ken
No way......see I woulda thought it was gonna be a pain......this forum has saved me so many times from doing things the hard way or taking things apart more than needed
Ken B
indiana
ken
So I have gently tried to push down and twist/rotate the gear shift and no luck. Could I be trying to do it too gently ? do you need to shove it down and give it a hard twist.....didnt want to go to hard first try
Ken B
indiana
ken
found this on youtube. I was pushing down on the gear shift. it is the outer ring that gets depressed and rotated.
chad112507
