Cab Bolt Diameter and Length!?
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
What is it??
Does it differ from year to year?
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
I can answer the last part of your question. LMC lists one kit for 73-87 trucks.
Tank6x2
Kurt
C30
The reason I ask is the dealership has zero information, I don’t have any parts breakdowns of the whole body style period. I’ve read the LMC Truck order book, but there’s no sizes. Thanks though.
1973c10
Don
When I order my cab bolts from LMC for my 73 the bolts they sent me where just a 1/2 X 4 bolt I could have got at any hardware store
1985c20
Torrington, CT
Chuck
I just bought the kit from LMC for an 85 and the bolts were flange head 1/2-13 by 3 1/2" long. Your 79 will have longer bolts for the rear 2 cab mounts if its a 4wd or 3/4 ton. I believe they are a 1/2-13 by 5" long
Tank6x2
Kurt
C30
:dogpile:You gentlemen are the feckin best!!! Just in the process of doing a 3” chop from the top, figure it should be tied down..
Tank6x2
Kurt
C30
Use a 1/2" bolt with a washer... Hope this helps.
Hard
