C to K conversion
ScottyB
Whatcom County, Washington
Scott
phantom
2 squirrels
So I have my 77 C30 and I am thinking about trying to convert to 4wd. I figure the easiest way to do this is to just pick up a donor vehicle and scavenge what I need off the donor. Question is, what years should I look at for a donor? My understanding is I will need to change the TH400 that I have as part of the conversion, so if possible I would like to find a 4L80 in the donor, but I don't know if that limits what I can take off it. What should I be looking for? What should I stay away from?
I suppose I should mention that this is not meant to be an off-road mudder or anything like that. I am looking for something I can use 4 season in the Cascade foothills. This truck can get a little squirrely when it is wet and I don't want to know how much worse that gets when we start getting snow and ice.
You'd be better off finding a solid 4x4 and either selling the c10 or using it for parts than going through the trouble and expense of making it a 4x4
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
He said it was a C30 which make it a lot harder to find a 4wd replacement. There are several write ups on here of other members that have done the swap. Last one I done I held out for a K30 frame and swapped it that way, but there getting real hard to find anymore
