Bulkhead connection check
SmashBack
Big 10
Hey guys, I'm about to do some re-wiring while swapping in a LQ4 engine. Between my color blindness, old faded wires and hard to read black and white wiring schematics I just want to be sure what I'm looking at. The labels I placed on the image are the numbers from the wiring harness schematic.
2J - connected to starter battery terminal
I believe this is the main power source that leads in to the cab?
3 - connected to HEI.
This is just switched power so I will use it to power my main IGN relay on my engine fuse box
6 - connected to starter S terminal
This just powers the starter relay so a 14awg should be ok as a replacement?
25 - connected to alternator
Don't think this will be needed since the PCM harness has it's own wire for this?
2E - connected to junction block on firewall which connects to alt output and starter battery terminal.
Looks like this feeds the IGN switch and a few fuses?
30 - fuel level sender
Yep, it feeds the headlight switch (but only for the H/L's - the other exterior lighting is supplied separately). Also supplies the BATT section of the fuse block (fuses TL/CTSY, HORN/DOME and the two plug-in sockets under the HORN/DM fuse)
Yes, it would normally be connected to the BATT terminal on the coil.
The wiring dwg shows it as 3mm (equivalent to 12 AWG) but 14 AWG should be okay.
And actually, if you have a gauge package, the BRN 25 is omitted inside the cab.
Yep, it feeds everything not supplied by the RED 2J circuit (described above).
Correct - it runs back to the sender within the rear lighting harness loom.
A couple more gauge leads are also shown below (DK GRN 35 & TAN 31) - coolant temp and oil pressure respectively.
Everything else in that section of the block is pretty much related to the windshield wiper.
SmashBack
Big 10
Just what I needed, thanks for the assistance!
gmachinz
Harnessworx Inc
Iowa
Jabin
Its not a dual tank truck is it?
SmashBack
Big 10
Nope just one lonely tank under there!
twzorek
