Brown/black advance wire - unplugged - idles better and runs about same.
Jwernatl
Senoia, GA
5.7ltr
Hey All, a few weeks back I set my fully warmed 350 timing to 1-2degrees - to do so, you know we have to unplug the advanced brown/black wire- I did
Once I got done - I plugged line back together, idle jumped from 600rpm to about 1100rpm, and the truck runs 'rich' to much fuel - or not burning it -
I'm wondering if my ECM is reading my temperature correctly. - or distributor out of wack? or how about vacuum line? Is there a vacuum line going to distributor?
reason...
Just fyi too - the next day I double checked my the timing - unplugged the brown/black wire - checked timing - it was perfect. I shut the hood, not putting the line back together.
And for a week, I've noticed the truck idling perfect. And, there was no 'rich - too much fuel smell' -
A few days ago- it hit me I didn't plug the advance wire back together.
I immediately checked, sure enough, it wasn't plugged together. I plugged it together - the idle jumped from about 650rpm to 1000 - and that smell is back.
I put a 195 thermostat in a few weeks ago - seems to be perfect.
Also - the idle being up like that - it makes my tranny and driveline "CLUNK" when I put it in reverse. with wire unpludgged - sooo much nicer.
Itali83
Maine
Ben
K10, 'burban C10, Jimmy
You need to shut the truck off after plugging the brown wire back together. Not sure why but every TBI truck I’ve got. I had to do that.
this is the sequence I use for setting timing.
Unplug brown wire, start truck, set timing, shut truck off, plug brown wire back in then start truck and run it.
try that.
Ben
Jwernatl
Senoia, GA
5.7ltr
I saw that somewhere too. So, I tried that - no difference.
Someone may have adjusted the base idle screw according to incorrect (retarded) ignition timing. You could also possibly have a vacuum leak.
Jwernatl
Senoia, GA
5.7ltr
Would anyone happen to have a diagram of vacuum lines for the '87 350 tbi? Im looking but, having a hard time with finding something definitive.
Jwernatl
Senoia, GA
5.7ltr
Jwernatl
Senoia, GA
5.7ltr
here's ZLA emission/vacuum lines sticker off my 87CHEVY v10 350...
  • Unknown[1].pdf
