Brake Lights
pintopkp
Yorktown, NY
Nick
Hello all. New square body owner here; an 1981 C20 Silverado apparently with the "heavy duty" package or whatever it is. The truck spent much of its life in Southern Cali and was very well taken care of so there's NO rust and everything has been kept in good shape. The only issue I'm having is the brake lights; all the other lights work fine (tail lights, signals, etc.), but both darned brake lights aren't working. I do know that the truck had a camper on it a while back (it now has a cap on it) so maybe the wiring was messed with to accomodate the camper. Just looking for someone to point me in the right direction. I'm ok with wiring (not great....just ok) so this will take a little bit of head scratching on my part. Thanks guys. Love the board by the way.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Here's a wiring diagram for the back lights...
attachment.php
If your turn signals work but the brake lights dont I would be looking first at the switch connected to the brake pedal under the dash. If it is adjusted right and getting contact when the pedal is pressed (check with continutity tester or test light) then I would move on down the harness along the driver's side inner frame rail. A camper tap might have been done somewhere near the cab/bed junction. Otherwise, if it has a towing hitch on the back I would look around the middle of the bumper for the tap for the hitch. You know what to look for, broken or worn wires, corroded contacts, etc.
pintopkp
Yorktown, NY
Nick
Thanks very much. I'll take a look this weekend and report back. Been a hectic week at work.
pintopkp
Yorktown, NY
Nick
Turns out it was the brake switch; works intermittently and sticks. Needs replacing. Anyone have the part # handy? Thanks.
I was late to this party, but would agreed, it's the brake light switch at the pedal.
Need to know if its Auto or Manual trans, Cruise control or no. Here is Rock Auto Part, NO Cruise with Auto Trans. for example. Looks like it's $3.
KEMPARTS Part # EG1092 More Information About this Part
Brake Light Switch w/o CRUISE CONTROL - w/AUTO TRANS - 4 TERMINALS [Wholesaler Closeout -- 30 Day Warranty]
Part Image
$2.66
Add
pintopkp
Yorktown, NY
Nick
Thanks again. I have C/C on my truck so I just grabbed the corresponding switch. Now I won't have to worry (as much) about someone running into the back of me.
boarder421
