Body mounts are shot!!!
Bossmanivy
Midlothian, VA
GMC Suburban
I've got a 90 suburban 1/2 ton 4wd. My body mounts are wasted and the body flexes off the frame. It sits fine on the frame. The mounts stick through the holes on the frame. I'm thinking of doing poly bushings and a 1" body lift from ORD. does anyone have pics of what a mount should look like. I think there might be some hardware missing. The body lift comes with bolts and the poly kit comes with a few washers but I'm not convinced I'll have everything I need. I don't want to order the whole stock kit from LMC and only use a few items from it. I'm not against spending a day at a wrecking yard either. I just want to make sure I have what I need before I dive in because this is my DD. thanks, Chris
chengny
Parts illustrations:
Parts lists with OEM part nunbers:
K10noob182
