Blown rear end in 86 K5 Blazer
Redddogg
Canada
Adam
K5 blazer
Been lurking here for awhile and finally making a post. I blew up the 12 bolt 3:08 rear end in my 86 blazer. I live in Toronto Canada and am having a hard time locating a used unit. What are my best options if I can find a unit with a different ratio? (I understand I'm going to have to change the front).
gpmorgan
Tupelo Ms.
greg
What do you mean "blown"?? Have you taken the cover off? It might be just as cheap to repair the one that's in it rather than having to replace both front and rear. But, if you've ever considered a gear ratio change, now would be the time.
austinado16
Central Coast, CA
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
I too suggest pulling the cover and seeing what happened. Good time to buy a new ring and pinion, maybe replace the OE limited slip (if it's got one) with a better unit, and inspect/replace the axle bearings, seals, and inspect the axles where the bearing chew....er, I mean, run.
Redddogg
Canada
Adam
K5 blazer
Sorry didn't have more info at the time of posting. It had an auburn posi in it that exploded and took out pretty much everything. The housing is not gouged or anything but it ruined pretty much everything. I don't have the space to work on it where I am and it's winter so outdoor is a no go. It's at a buddies shop right now. Parts and labour to rebuild mine is about $1800 which I'm not prepared to spend on it and 12 bolt 3:08's are apparently hens teeth in these parts.
Redddogg
Canada
Adam
K5 blazer
Update. I found a front and rear 12bolt 3.08 only an hours drive away for $200 for both. Hopefully they are serviceable.
gpmorgan
Tupelo Ms.
greg
Definitely a good price. Hopefully they will be good. Good luck.
PS. Welcome to the forum.
Redddogg
Canada
Adam
K5 blazer
Thanks. I'm crossing my fingers, that price is almost too good to be true. The next one was 6 hrs away and $400 for the rear alone. I'm hoping that I can just pull the guts and keep my old housing as this one has been sitting outdoors for some time.
Redddogg
Canada
Adam
K5 blazer
Picked up the axels today. Front is totally complete with steering dampener attached that looks in good shape, and rear is good too. Even got a spare Dana 44 front housing with tubes as a bonus. Should get things going tomorrow or Monday.
kains77
