Blazer/Jimmy Complete Exhaust Systems
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
Greetings gentleman! I may be nearing the stage of my exhaust system on the Jimmy. Right now i'm down to the manifolds, nothing else. I intend to replace them with OEM and steering away from headers. From here, what are some options/kits, etc. Want to know where to buy best, what to buy best. I intend to weld them, obviously installing new hangers since 80% of them are already missing. Pictured below is pretty much the only picture of it with the prior exhaust. It was a joke, one of the first things to go. As always, thank you.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
I'm looking at LMC's options, from new manifolds to the entire setup. It doesn't look that bad. Optional glass packs, "bolts together" and comes with hangers. Any thoughts?
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I'd try to find GM manifolds if possible
I dont know what exhaust systems LMC has to offer but I did a Hooker clamp together system with Hooker Super Comp Turbo mufflers years ago and was very pleased with how it turned out. It lasted ten years as my daily driver & was actually still useable when I boke the truck down for restoration after it sat for another decade.
This time I ordered a Flowmaster universal kit with Flowmaster hushpower mufflers, it was a lot more work tinkering to get the fit just right but I am real pleased with how it turned out. I used exhaust hangers from summit that were just a 3/8" rod mounted into a rubber isolator that bolts to the frame or crossmember, tacked them to the tubing then heated and bent them like "J" hooks to finalize them.
img_7643-jpg.263558
Hooker has some decent kits according to a buddy of mine, they're slip fit and give you some options for lengths and routings, then you could weld them all up. That wasn't out when I built my truck. I couldn't find anything I liked so I just went to an exhaust shop and had it all done. That's probably your best bet honestly.
Jleopard77
