Best way to pull this 350
Gman73
Sacramento
Gary
Ck20
350 v8
The manifold bolts came off easily but impossible the ones at the exhaust pipes, should I yank the transmission or just the engine and disconnect at the clutch housing? I’ve never done one before.
Supporting Member Army
Since its a manual, you can pull the 4 bolts that hold the trans to the bellhousing and leave the bellhousing bolts in place. You will need to put a ratchet strap or similar underneath the transmission to support the front of it when you slide the engine off the input shaft of the transmission or you could bend or break something. Alternatively, you can unbolt the transmission from the adapter and transfercase and pull the entire engine/trans out together.
Gman73
Sacramento
Gary
Ck20
350 v8
Thank you, I think I’ll pull the whole unit with the transmission since I’m going to re seal it anyway then I’m going to convert my np 205 to a twin stick so eventually it’s all coming out
Camar068
Air Force Supporting Member
10 yrs Air Force
I pulled a 350/700r4/np208 all at once. Then installed a LM7 5.3/4l60e/np208 all at once. With all that I made sure not to make sudden/jerky movements just in case.
workinman789
