Bench Seat to Bucket Seats (Ideas & Discussion)
Stroked
Beloit, Kansas
Jared
Hmm....it's been so long since I've taken a bench seat out that I can't remember what that bracket looks like. Both my squares are an hour away too so I can't go out and look.
My motor and tranny are here though. Too bad it's 108 degrees outside. Not exactly wrenching-friendly weather.
J Knight
Baytown TX
82 Chevy
350ci
This is the factory buckets out of a reg cad how I got them with ALL the brackets etc.
attachment.php
Close up of brackets, tracks, and floor perches.
attachment.php
Bench seat left side.
attachment.php
Bench seat right side.
attachment.php
Rear part of bench tracks.
attachment.php
J Knight
Baytown TX
82 Chevy
350ci
Floor perches installed.
attachment.php
Floor perch close up.
attachment.php
attachment.php
Drivers side seat with tracks installed.
attachment.php
Passenger seat with stationary brackets installed.
attachment.php
Stroked
Beloit, Kansas
Jared
Ohh...now I get it. Lol. Looks like my tracks sit a little farther out too.
Eh, I still think I can fab something up without too much cursing and throwing things. If not I'll just throw a ratchet strap over and cinch em down. :grd:
Stroked, the rear of the bench tracks have a v shaped bracket riveted to the back and the factory buckets tracks have a flat bar riveted to the back but the seat track itself is the same. The passenger seat is stationary but can be moded to be a slider with another set of brackets.
Except the buckets have a front bracket that bolts to the seat and bolts to the tracks, in between the two. That bracket only came with the rare pickup buckets. I was not aware of the pickup buckets having a front mounted slider knob (that could be adapted to the passenger side)... until I saw your pics.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Not shown here is the front brackets that must still be bolted to the driver seat. ^^^
In these pics of yours, those front brackets are visible...
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Also, your seat brackets are completely different than mine (passenger side). My fronts are stamped a little different, but the rears stick out behind the seat, and bolt to the rear ledge of the cab. They are a pain to get at.
Just use tie wire and duct tape. The seat belts are bolted to the floor anyway, so the seat can get to far away from you. You'd be jacked if the belts were integral with the seats though.
Dem is purdy. I'd like to have buckets in one of my trucks. Probably the 84C20 that's gonna have the Olds 455 in it. And I intend to build a console in good taste that will house the B&M Ratchet shifter, and a nice subwoofer.
Suburban bucket seat tracks will probably let you bolt them right in. I took a ton of pics today, I think I'll start a thread showing the various tracks and mounts between the truck, K5, Burb, and crew cab. Bench seats too.
J Knight
Baytown TX
82 Chevy
350ci
Yea Andy, these buckets came out of an 82 cab and chassis one ton (reg cab). The rear brackets use the seat belt bolts on both sides. Here are some of my mock up pics.
attachment.php
attachment.php
attachment.php
attachment.php
I wanted to get those bucket seat out of the Burb I scrapped for that kid. But I don't think his were OEM. It looked like someone built a rack for them to bolt to using the OEM 4 outside bolts. I'd have even taken the rack cuz it was a good classy job, but I ran out of time, and didn't have someone to hold the bottlm nuts the way they had installed it. So to the scrap yard they went. :sad72:
attachment.php
attachment.php
attachment.php
attachment.php
So this is the real OEM pick up truck seats the way it would have been done at the factory. :High 5:
J Knight
Baytown TX
82 Chevy
350ci
Yes sir, these seats are the real deal OEM from GM for reg cab squares.:)
That's a MUCH better design. The earlier setup puts the back of the seat right against the cab wall and it's flimsy enough you can grab the seat and wiggle it some.
J Knight
Baytown TX
82 Chevy
350ci
I wasnt expecting them to be that way, they were the first ones Ive seen that attatch at the seat belt and are very sturdy.
Subscribed. Bumped.
sirex
