BBC Clam Shells
Marine Corps Moderator
I'm looking for a set of BBC clam shells. I put my BB in my Blazer today, got one motor mount bolt in, and the other one does not line up. I used SB clam shells and I'm pretty sure that's my problem. I looked at the Extracab that has a BB in it, and the clam shells look shorter. Let me know if you have a set.
Moderator
If you are using small block rubber/urethane mounts, then the smalblock clamshells are correct. Depending on the brand and or condition of the mounts, it can take some finesse to get both bolted up. Even if you were installing a small block too.
No... using Energy Suspension. The Clam Shell is about 1/2 inch off. The Small block clam shells look to long. The clam shells on the Extra cab look shorter. Im going to try and measure them in the morning.
Moderator
Yeah, sometimes the poly inserts don't fit in the mount halves perfectly and the bolt holes can be off a bit. Small block mounts work in conjunction with small block clamshells. If you use big block clamshells, you should need the big block mounts too that use different bolt holes in the frame.
Moderator
Small block and big block engines share an identical mounting footprint. The mounts and clamshells are only different between the two (for some applications) for a slightly different mounting height within the engine compartment.
On a 4x4 there are no different bolt holes. The clam shells fit over the motor mounts, the the motor mount bolt doesn't line up. I can get one side in. The other side is off by about 1/2 inch. I'll get some pics.
ancil
