Bad miss - could use some thoughts from y'all
BigT
Firefighter EMT/First Responder
Selah, WA
Tim
Scottsdale K20
My 350 developed a very bad miss a couple days ago, like it dropped 1 or 2 cylinders. HEI, mild cam, bought it used last fall, ran great until this issue, though it has been dieseling a bit when I shut it down hot. Plugs are new, wires and cap are all attached and in good shape, so I do not suspect and ignition issue - though I suppose it could be a bad module. My next course of diagnostic action is to check compression and go from there. Any other thoughts or things to look for?
BigT
fast 99
Spokane, Washington
Can remove plug wires one at a time running to possibly isolate cylinder.
Checking compression might narrow it down.
A vacuum gauge is a good diagnostic tool for misfires, faster and easier. Many times will show a mechanical fault.
Check for vacuum leaks.
Dieseling suggests a vacuum leak or high idle.
Disregard the line.
77Dmax
vt
Joe
Get an infrared thermometer and check temps at the exhaust ports. Your cold cylinders are the dead ones. Start diagnosing from there.
I do the same with my fingers have for like 30 years wet your fingers touch the manifold,use common sense. Some ports will sizzle,some won't.
77Dmax
vt
Joe
That works too.
That works too.
Only mentioned it because infrared thermometers didn't use to be cheap,and not everyone has one. But absolutely, checking exhaust temperature no matter how, is a fantastic diagnostic tool.
