Aux tank usage?
72chevy2door
Florida
Jeff
1500 Sierra Classic suburban
I know this may sound stupid but how do I use the other tank? Currently I'm using the driver side tank but I would like to see if the passenger side will work too. I read the solenoid valve thing goes out commonly and would like to test it. I tried looking through the owners manual but it didn't describe how to do it. Any help is much appreciated
scottybaccus
Central Texas
Scotty
GMC R1500
See a big rocker switch on the dash near your ashtray? Flip it and watch for the fuel gauge to change.
72chevy2door
Florida
Jeff
Do I do it while it's runnibg or while key is in the off/on position? I don't want to damage anything.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
You won't damagae anything you can flip it whenever.
firebane
Calgary, AB
Curtis
Either running or key in the run position but not started. It needs 12v.
72chevy2door
Florida
Jeff
Thank you guys. Well it really don't matter now though. I went to put fuel in it she took it then about an hour later I was stil smelling fuel real strong so I climbed under neath and the tank is wet... So I'm assuming a small hole or something. Oh well paid $500 for the truck can't complain cause it's about to be a daily driver.
72chevy2door
Florida
Jeff
But I do ask this. If my selector valve is bad or faulty where would the best place to purchase one and what is the ones to stay away from as far as bad quality?
rich weyand
Bloomington Indiana
Rich
I think the 88 had the motor driven valve. They're not cheap. Pollak makes the good ones.
See if this looks like yours. The older solenoid valve only had one wire to it. This should have five.
https://www.rvsupplyparts.com/catal...ve-7840.html?gclid=CJ_puM7Xj8QCFQ4vaQodEmIAHg
Also, if you can see where the fuel leak is coming from, I have successfully lightly sanded around a leak in a fuel tank and sealed it with a coating of JBWeld about as big around as a silver dollar. It held as long as I had that vehicle.
72chevy2door
Florida
Jeff
Where would this valve be at? It's a 1986 Silverado LWB pick up
72chevy2door
Florida
Jeff
Will the bed have to be removed in order to access it? If so I will just run the single tank until I lower the truck and build it up
firebane
Calgary, AB
Curtis
The valve? No. But probably wouldn't hurt to use some ramps or jackstands to give a bit more room.
87silveradok20
Ohio
Levi
Silverado k20
i dont think you have to pull the bed. At least not on a crew cab
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
You don't have to remove the bed it should be right on the crossmber in front of the tanks, my 79 has it on the passenger side.
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
Passenger side under the cab and covered by a heat shield on mine.
jbwhitford
