- Mar 5, 2014
- Kansas City, Missouri
- ryan
- r10
I bought the Autometer phantom speedometer, mechanical not electric, and did not realize it has a screw on cable connection. I looked around on other forums and found some info on an adapter that Summit sold, stated you had to contact them directly as it was not in their catalog nor online. Contacted Summit and they no longer carry it or it is not made anymore by the carrier. An adapter that has a snap on end with a threaded end on the other. Anyone come across something like this for their speedo? I've found replacement cables that are threaded that are various lengths and I'm kinda wanting to avoid fishing a new wire in and old one out. But if it comes to it do what you gotta do right?
Correct me if I'm wrong but I read that the th350 and 700r4 could use the same speedo cable that the gears in the tail were similar. My Gpa switched out the 700r4 to a th350 sometime between 1987-90. I know the '87 came with a mechanical speedo just unaware if he had to change out the cable when he did the trans swap.
