Are K10/K1500 Pick Up Frames the same as K20/K2500 Frames???
Oh ide do the conversion for you. If the truck was a K20 Ide be interested in it. Remember me saying my cousin had a K20 with the 6.2 in it? I guess I need to find out for sure what year it is I might have one located for cheap and not even realize it but cant remember if it is an 83 or if it was an 84
Yeah, I'm wondering why you haven't been all over that truck. Really, I think you need to research the K10 and K20 frames. I am farily certain in the K series, they are the same frame. Same thickness, tensile strength and all. Almost positive about that.
But, see what you can find out to confirm or deny that the K10/K1500 and K20/K2500 frames are the same or differant. I want to say they are the same for some reason, I am not finding the info now but will continue to find out as time permits. I want to know myself too for reasons. I want the strength but I also want the flex. When I was checking into this before, someone had mentioned for wheeling the K10/K20 frame is better for flexing and lighter weight than the K30, which I knew, so some wheelers even prefer the K10/20 frame and tranfer K30 springs and axles. Mostly for the Rock Crawlers. I am not so much interested in Rock crawling as I am mud basically. Actually not even mud, but trail and hill climbing moreso than anything. So yeah, its important to know for both you and I. I kinda want to do the same thing you are doing, we might end up with twinkie trucks if I ever get the funds. But, I like the 454 better in the Vortec cuz it gets away from the spider injectors, also goes better with the 4L80-E. But, we'll see what we find and go from there. Oh, and I wouldn't even mind mine being in a Blazer or Burb. I only tow bumper pull trailers.
Here we go Pops. I don't mind linking to another one of Shaggy's sites, but this guy here says, K10 and K20 frames are even the same part #. This would be the 2nd source that tells me so. I can't find the other source. Its all a matter of putting 3/4 ton springs and the 14B FF in the rear, and putting 8 lug hubs and rotors on the front. That's it. Simply done. It doesn't work this way on the C10 and C20, but it does on the K10 and K20.
http://www.gmfullsize.com/forum/showthread.php?p=3046357
Good investigating. :High 5: :popcorn:
Well, I want more proof than that. Just cuz 1 guy says it, doesn't mean its true. But I forget where and how I got the definate info at one time, but now can't find it. Seems a guy worked for a body shop and had all the crossover info, and a K10 and K20 frame are the same for the right years. The V10 and V20 frames are the same too, but a differant part # than the K10 and K20, then of course the differant part #'s for 80 are earlier too, but still even then, the K10 and K20 for those years was the same, as is also for the 67-72 K10 and K20 are the same. This is only in the 4x4 frames though, not 2wd.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Frm the Hollander...
CHEVROLET 10 PICKUP 84-86 4x4; 131.5" WB
CHEVROLET 20 PICKUP 84-86 4x4; 8-350 (5.7L), VIN (8th digit) "L"
CHEVROLET 20 PICKUP 84-86 4x4; 8-379 (6.2L, diesel), VIN (8th digit) "C"
GMC 1500 PICKUP 84-86 4x4; 131.5" WB
GMC 2500 PICKUP 84-86 4x4; 8-350 (5.7L), VIN (8th digit) "L"
GMC 2500 PICKUP 84-86 4x4; 8-379 (6.2L, diesel), VIN (8th digit) "C"
A ----------
CHEVROLET 10 PICKUP 81 4x4; 131.5" WB
CHEVROLET 10 PICKUP 87 4x4; 131.5" WB
CHEVROLET 20 PICKUP 81 4x4
CHEVROLET 20 PICKUP 82 4x4; 6-292 (4.8L)
CHEVROLET 20 PICKUP 82 4x4; 8-350 (5.7L), VIN (8th digit) "M"
CHEVROLET 20 PICKUP 82 4x4; 8-379 (6.2L, diesel), VIN (8th digit) "J"
CHEVROLET 20 PICKUP 83 4x4; w/HD suspension
CHEVROLET 20 PICKUP 84-86 4x4; 6-292 (4.8L)
CHEVROLET 20 PICKUP 84-86 4x4; 8-350 (5.7L), VIN (8th digit) "M"
CHEVROLET 20 PICKUP 84-86 4x4; 8-379 (6.2L, diesel), VIN (8th digit) "J"
CHEVROLET 20 PICKUP 87 4x4; up to 8500 lb GVW
GMC 1500 PICKUP 81 4x4; 131.5" WB
GMC 1500 PICKUP 87 4x4; 131.5" WB
GMC 2500 PICKUP 81 4x4
GMC 2500 PICKUP 82 4x4; 6-292 (4.8L)
GMC 2500 PICKUP 82 4x4; 8-350 (5.7L), VIN (8th digit) "M"
GMC 2500 PICKUP 82 4x4; 8-379 (6.2L, diesel), VIN (8th digit) "J"
GMC 2500 PICKUP 83 4x4; w/HD suspension
GMC 2500 PICKUP 84-86 4x4; 6-292 (4.8L)
GMC 2500 PICKUP 84-86 4x4; 8-350 (5.7L), VIN (8th digit) "M"
GMC 2500 PICKUP 84-86 4x4; 8-379 (6.2L, diesel), VIN (8th digit) "J"
GMC 2500 PICKUP 87 4x4; up to 8500 lb GVW
B ----------
CHEVROLET 20 PICKUP 87 4x4; over 8501 lb GVW
GMC 2500 PICKUP 87 4x4; over 8501 lb GVW
|B| fits |A|; difference is GVW.
A ----------
B ----------
:Pshyco:
A ----------
B ----------
So what you are saying then, according to Hollander, all the 81-87 K10/K1500 frames are the same part # as 81-87 K20/K2500???
If tha's what you're saying Hollander says, then I say that's justified proof enough, the K10 and K20 frames are the exact same.
So the only differance then will be, the rear springs, the rear end with 3/4 ton brakes, and the front hubs with 8 lug rotors and 3/4 ton calipers, and likley the Master Cylinder maybe a differant # since you'd hope the master might have a little bigger bore for the 3/4 ton. I wouldn't be suprised though if it doesn't.
RetroC10Sport
Jay
pontiac aztek
The Hollander is gospel...:D Though if you look at it, it's saying 1981 AND 1987 K10 frames are the same as 1981 TO 1987 K20 with HD suspension frames. 1984-86 frames are the same too...
Though it is slightly wrong on a blower motor for a 1990-96 GM FWD minivan...Says Eldorado fits and they are as different as apples and cockroaches.
RetroC10Sport
Jay
pontiac aztek
For 1982:
CHEVROLET 10 PICKUP 82-83 4x4; 131.5" WB
CHEVROLET 20 PICKUP 82 4x4; 8-350 (5.7L), VIN (8th digit) "L"
CHEVROLET 20 PICKUP 82 4x4; 8-379 (6.2L, diesel), VIN (8th digit) "C"
CHEVROLET 20 PICKUP 83 4x4; w/o HD suspension
GMC 1500 PICKUP 82-83 4x4; 131.5" WB
GMC 2500 PICKUP 82 4x4; 8-350 (5.7L), VIN (8th digit) "L"
GMC 2500 PICKUP 82 4x4; 8-379 (6.2L, diesel), VIN (8th digit) "C"
GMC 2500 PICKUP 83 4x4; w/o HD suspension
And the reason this could be is, and many are not aware of this, and you can check this for me too to verify the validity, but C10/C1500 's can have either 52 or 56 inch rear springs. Also, K20/K2500 can have 52 or 56 inch rear springs. All other models have 1 or the other. Example, ALL K10/K1500's have 52in rear springs, ALL C20's have 56in rear springs.
Only the 2wd half ton, and the 4wd 3/4 ton can have either spring size.
But, I am a little confused, I guess becasue you are not including a part #. So it these 82 Frames differant from all the rest above???
Here is the excerpt from one of my first threads I ever posted here.
Ever wondered what size leaf springs you have on your Squarebody truck? Here is some info I put together for another forum that obviously didn't appreciate it much. I have a K10 that I am converting to a K20. This research answered alot of my questions for me. Notice a C10 and a K20 are the only models that could possibly have either the 52 or the 56 inch springs depending on the RPO code and factory installed equipment. BTW, both frames C and K are punched to be able to accept both size springs. The spring hangers are the same for 52 or 56 inch springs. So if you want to change your spring size, simply grind off the rivets, and use grade 8 bolts to relocate your spring hangers in the other set of holes already punched in your frame from the factory. One of the many things I love about GM, making things very universal and interchangeable. But, do keep in mind, C and K frames do use differant spring hangers. So although you can move the hangers to change your spring size, you must use K hangers for the K frame, and C hangers for the C frame. Very simple if whatever truck you are working on, simply use the same hangers on the truck you are working on, and they can be relocated without any fabbing or welding whatsoever.
Front Leaf Springs
K10, K20, and K30 Use the same springs. Differance is, they come in 2 leaf, 3 leaf or 4 leaf set up. All 3 set ups are interchangeable between all 3 models.
I'd imagine the K30 comes in the 4 leaf set up, but the K10 and K20 could be either the 2 or 3 set up depending on heavy duty RPO code or not.
Rear Leaf Spring 2WD C10, C20, C30.
C10 can be 52 inch or 56 inch springs. Depending on Heavy Duty RPO code.
C20 is 56 inch springs. # of leafs and thickness of spring pack depends on RPO code, ie... Smooth Ride, Heavy Duty etc.
C30 is 56 inch springs. # of leafs and thickness of spring pack depends on RPO code. 10 Leafs is Heavy Duty 1 ton.
Rear Leaf Springs 4WD K10, K20, K30.
K10 is 52 inch springs. # of leafs and thickness of pack depends on RPO code.
K20 can be 52 inch or 56 inch springs. Depending on Heavy Duty RPO code or not. (Appears that 52 inch may be more common)
K30 is 56 inch springs. # of leafs and thickness of spring pack depends on RPO code.
So becasue I am converting my K10 to a K20, with drum to drum axle swaps, I am also moving the rear spring hangers on the K10 which currently has 52 inch 1/2 ton springs, and I will be installing heavier 56 inch springs off of a C20 donor truck. For my 85 K10, the master cylinder is also the same for either the K10 or K20.
RetroC10Sport
Jay
pontiac aztek
If I had a part number, i would post it, but alas, i don't.
518-291 no.
A ----------
BLAZER/JIMMY (full size) 73-74 4x2, 4 leaf, 2-1/2" wide front bushing
CHEVROLET 10 PICKUP 75-87 4x2, 4 leaf
GMC 1500 PICKUP 75-87 4x2, 4 leaf
SUBURBAN 10 75-87 4x2, 4 leaf
SUBURBAN 1500 75-87 4x2, 4 leaf
2-1/2x26x26xRB117xRB117 {11}
The "RB" references in the spring sizes are "S. R. I." bushing dia. codes.
|A| thru |D| interchange in pairs; difference is number of leafs.
B ----------
BLAZER/JIMMY (full size) 73-74 4x2, 5 leaf
BLAZER/JIMMY (full size) 73-74 4x4, 5 leaf
BLAZER/JIMMY (full size) 75-88 5 leaf
CHEVROLET 10 PICKUP 73-87 4x4, 5 leaf
CHEVROLET 10 PICKUP 81-87 4x2, 5 leaf
CHEVROLET 20 PICKUP 73-87 4x4, 5 leaf
GMC 1500 PICKUP 73-87 4x4, 5 leaf
GMC 1500 PICKUP 81-87 4x2, 5 leaf
GMC 1500 PICKUP 88 5 leaf (4x4)
GMC 2500 PICKUP 73-87 4x4, 5 leaf
SUBURBAN 10 73-87 4x4, 5 leaf
SUBURBAN 10 81-87 4x2, 5 leaf
SUBURBAN 10 88 4x4 (5 leaf)
SUBURBAN 1500 73-87 4x4, 5 leaf
SUBURBAN 1500 81-87 4x2, 5 leaf
SUBURBAN 1500 88 5 leaf (4x4)
SUBURBAN 20 73-87 4x4, 5 leaf
SUBURBAN 2500 73-87 4x4, 5 leaf
C ----------
BLAZER/JIMMY (full size) 73-74 4x4, 6 leaf
BLAZER/JIMMY (full size) 75-88 6 leaf
CHEVROLET 10 PICKUP 73-87 4x4, 6 leaf
CHEVROLET 20 PICKUP 73-79 4x4, 6 leaf
GMC 1500 PICKUP 73-87 4x4, 6 leaf
GMC 2500 PICKUP 73-79 4x4, 6 leaf
SUBURBAN 10 73-87 4x4, 6 leaf
SUBURBAN 1500 73-87 4x4, 6 leaf
SUBURBAN 20 73-79 4x4, 6 leaf
SUBURBAN 2500 73-79 4x4, 6 leaf
D ----------
BLAZER/JIMMY (full size) 73-74 4x4, 7 leaf
BLAZER/JIMMY (full size) 75-88 7 leaf
CHEVROLET 10 PICKUP 73-87 4x4, 7 leaf
CHEVROLET 20 PICKUP 73-79 4x4, 7 leaf
GMC 1500 PICKUP 73-87 4x4, 7 leaf
GMC 2500 PICKUP 73-79 4x4, 7 leaf
SUBURBAN 10 73-87 4x4, 7 leaf
SUBURBAN 1500 73-87 4x4, 7 leaf
SUBURBAN 20 73-79 4x4, 7 leaf
SUBURBAN 2500 73-79 4x4, 7 leaf
I also noticed, I already check the Master Cylinder part #'s for K10 and K20 and they are the same. For real, this conversion of a K10 to a K20 is as simple as boiling water if you acquire the 3/4 ton rear springs, 3/4 rear axle, and 8 lug hubs and rotors. Its that easy.
RetroC10Sport
Jay
pontiac aztek
1 ton:
518-525 no.
|A| thru |H| interchange as shown in notes.
A -----------
GM $334 obs
6 leaf.
2-1/2x26x30xRB117xRB117
|B| & |C| fit; difference is number of leafs.
|D| thru |G| fit; difference is bushing dia. & number of leafs.
A ----------
CHEVROLET 10 PICKUP 79-87 4x2, 6 leaf
CHEVROLET 20 PICKUP 73-87 4x2, 6 leaf
CHEVROLET 30 PICKUP 79-80 main spring, 4x2, 6 leaf
GMC 1500 PICKUP 79-87 4x2, 6 leaf
GMC 1500 PICKUP 88 6 leaf (4x2)
GMC 2500 PICKUP 73-87 4x2, 6 leaf
GMC 3500 PICKUP 79-80 main spring, 4x2, 6 leaf
SUBURBAN 10 79-87 4x2, 6 leaf
SUBURBAN 10 88 4x2 (6 leaf)
SUBURBAN 1500 79-87 4x2, 6 leaf
SUBURBAN 1500 88 6 leaf (4x2)
SUBURBAN 20 73-87 4x2, 6 leaf
SUBURBAN 2500 73-87 4x2, 6 leaf
B ----------
CHEVROLET 20 PICKUP 80-87 4x2, 7 leaf
GMC 2500 PICKUP 80-87 4x2, 7 leaf
SUBURBAN 20 80-87 4x2, 7 leaf
SUBURBAN 2500 80-87 4x2, 7 leaf
B -----------
GM ('80-87) $349 obs
7 leaf.
|C| fits; difference is number of leafs.
|D| thru |G| fit; difference is is bushing dia. & number of leafs.
C ----------
CHEVROLET 10 PICKUP 73-79 4x2, 8 leaf
CHEVROLET 20 PICKUP 73-79 4x2, 8 leaf
CHEVROLET 30 PICKUP 73-78 main spring, 8 leaf
CHEVROLET 30 PICKUP 79 main spring, 4x2, 8 leaf
GMC 1500 PICKUP 73-79 4x2, 8 leaf
GMC 2500 PICKUP 73-79 4x2, 8 leaf
GMC 3500 PICKUP 73-78 main spring, 8 leaf
GMC 3500 PICKUP 79 main spring, 4x2, 8 leaf
SUBURBAN 10 73-79 4x2, 8 leaf
SUBURBAN 1500 73-79 4x2, 8 leaf
SUBURBAN 20 73-87 4x2, 8 leaf
SUBURBAN 2500 73-79 4x2, 8 leaf
C -----------
GM ('73-79) $299 obs
8 leaf.
|D| fits; difference is bushing dia.
|E| & |G| fit; difference is bushing dia. & the number of leafs.
D ----------
CHEVROLET 20 PICKUP 80-87 4x2, 8 leaf
CHEVROLET 20 PICKUP 80-87 4x4, 8 leaf
CHEVROLET 20 PICKUP 88 (8 leaf)
CHEVROLET 2500 PICKUP 89-90 VIN models "R/V" (Crew Cab, 8 leaf)
CHEVROLET 30 PICKUP 79-80 main spring, 4x4, 8 leaf
GMC 2500 PICKUP 80-87 4x2, 8 leaf
GMC 2500 PICKUP 80-87 4x4, 8 leaf
GMC 2500 PICKUP 88 VIN models "R/V" (8 leaf)
GMC 2500 PICKUP 89 VIN models "R/V" (Crew Cab, 8 leaf)
GMC 3500 PICKUP 79-80 main spring, 4x4, 8 leaf
SUBURBAN 20 80-87 4x4, 8 leaf
SUBURBAN 20 88 (8 leaf)
SUBURBAN 2500 80-87 4x2, 8 leaf
SUBURBAN 2500 80-87 4x4, 8 leaf
SUBURBAN 2500 88 (8 leaf)
D -----------
GM 4x2 ('80-90) $421 obs
GM 4x4 ('80-88) $388 obs
8 leaf.
2-1/2x26x30xRB136xRB117
|C| fits; difference is bushing dia.
|E| fits; difference is the number of leafs.
|G| fits; difference is bushing dia. & the number of leafs.
E ----------
CHEVROLET 20 PICKUP 73-79 4x2, 9 leaf
CHEVROLET 30 PICKUP 73-78 main spring, 9 leaf
CHEVROLET 30 PICKUP 79-80 main spring, 4x2, 9 leaf
CHEVROLET 30 PICKUP 79-80 main spring, 4x4, 9 leaf
CHEVROLET 30 PICKUP 81-88 main spring, 9 leaf
CHEVROLET 3500 PICKUP 89-91 VIN models "R/V", main spring, 9 leaf
GMC 2500 PICKUP 73-79 4x2, 9 leaf
GMC 3500 PICKUP 73-78 main spring, 9 leaf
GMC 3500 PICKUP 79-80 main spring, 4x2, 9 leaf
GMC 3500 PICKUP 79-80 main spring, 4x4, 9 leaf
GMC 3500 PICKUP 81-87 main spring, 9 leaf
GMC 3500 PICKUP 88-91 VIN models "R/V", main spring, 9 leaf
SUBURBAN 20 73-79 4x2, 9 leaf
SUBURBAN 2500 73-79 4x2, 9 leaf
E -----------
GM 2600 LB. ('73-79) $312 obs
GM 2850 lb. ('73-79) $337 obs
GM 3500 LB. ('73-91) $528
GM 3750 LB. ('87-91) $446
9 leaf.
|H| fits; difference is bushing dia. & the number of leafs.
G ----------
CHEVROLET FORWARD CONTROL 89-92 30 Series; disc rear brakes, main spring, 9 leaf
GMC FORWARD CONTROL 89-92 3500 Series; disc rear brakes, main spring, 9 leaf
G -----------
GM $386 obs
9 leaf.
2-1/2x26x30xRB129xRB129
|E| fits; difference is bushing dia.
|H| fits; difference is the number of leafs.
H ----------
CHEVROLET FORWARD CONTROL 79-92 30 Series; disc rear brakes, main spring, 10 leaf
CHEVROLET 30 PICKUP 81-88 main spring, 10 leaf
CHEVROLET 3500 PICKUP 89-91 VIN models "R/V", main spring, 10 leaf
GMC 3500 PICKUP 81-87 main spring, 10 leaf
GMC 3500 PICKUP 88-91 VIN models "R/V", main spring, 10 leaf
GMC FORWARD CONTROL 79-92 3500 Series; disc rear brakes, main spring, 10 leaf
H -----------
GM $527
10 leaf.
Exact fit only.
smallblocksa
