Any good hacks/upgrades you've come up with for our trucks
bluex
Spartanburg SC
C15
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
With the exception of troublesome power steering pumps my serpentine belt system upgrade is one of my favorites. It wasnt necessarily cheap though.
is that a factory ac/ps bracket just equiped with a/c delete pulley?
what length is your belt?
edit: disregard, I'm reading your build thread now...I hate search, I'll search specific phrases that I know I've read on here to reread them, and it'll return ''no items match this search''
roundhouse
atlanta ga
justin
77,78,79,80 ?
I installed a 5.3 backed by a NV-3500 five speed and Vintage Air
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
The aluminum slotted rims are so much better than the fake bead locks.
hatzie
k20
Thanks, used a hole saw. Can use a drill instead, but was easier to put it on a mill
The rigidity of the vertical milling machine and the way you clamp it to the table is what keeps the hole saw from wandering and making a mess of the hole. A handheld drill or even a drill-press wouldn't give the same clean results.
bluex
Spartanburg SC
C15
you bought a L31 block based motor so you cant follow what I did with the water pump. You need to use the 96+ pump and pulley to match your block.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Thanks, I caught that once I started reading your thread. I started at page 1, so it took a while. Your truck’s stance looks sweet, btw
bluex
Spartanburg SC
C15
Thanks, you must have been pretty bored to read it all lol
4WDKC
Southern Florida
Kacy
Sorry this didn't post over the weekend
Sent from my Nexus 5X using Tapatalk
4WDKC
Southern Florida
Kacy
installed the aluminum hvac door actuator bracket today. There are also versions with a simpler replacement from a gate latch
Thats nice where did you find it?
yevgenievich
Place
Name
Year
Model
Size
gmt400 wheels look good to keep original style in case originals hard to find. Need conversion lugnuts in order to use the caps. Older squares are standard thread, while the caps for the hub cap are metric.
tobiahr
Atascocita, Tx
Tobiah
Blazer 2wd
L59 5.3 swap
Everyone talking about hidden switches so I figured I would share mine. Did a steering column replacement and installed a free salvaged 96 or 97 column in my old 82 Blazer. After rewiring all of the new switches to my accessories I had the floor switch for the high beams free and spliced into the power wire for the HEI. Perfect stealth switch as now one asked what it was for and always assumed it was still high beam switch. I even killed the engine while driving one night because I forgot that was what it was for :)
Dutch Rutter
Independence, Or
Joshua
Small tach instead of clock or trans temp gauge instead of clock.
A little late to the party here, but I like the OEM temp gauge in place of the clock and was hoping to get more info on how you did it? That gauge looks to be just another water temp with the symbol removed?
h3adbang3r14
Ohio
markus
k20
sbc 400 from 78 k30
cucv have em stock for blackout for mission critical Operations
my truck's previous owner had a couple hidden 3 position switches put in. they're down near the fuse block left of the column. anyway i was wiring something in and when i was finished everything as far as the new accessory worked out great. then i went to drive the truck to my blind early a few days later and the tail light weren't working. i thought i accidentally messed something up. it turns out i bumped one of those switches by mistake. i've yet to trace them both to where they go, but the one 3 position switch disables lights in different combinations. turns out i can black the truck out so even the brake lights won't work. dude mustve been a poacher or drug runner, haha!!! unless other cucv trucks have this option to sneak around...
twitch1989
