BrianCarroll
- Dec 2, 2021
- Minnesota / Arizona
- Brian
- c-10 sport
- 5.3 LS swap
Ok brand new to this forum but have read many posts. Be patient with me.
1979 c-10 SPORT (which is rare) and 2 wheel drive 5.3 LS SWAP
I have a sm 465 but is leaking gear lube at front of trans I dont know if it is in the bell housing yet I suspect the front bearing and seal. Although there are no bearing symptoms.
What I want to avoid is ruining the new clutch that just went in a few thousand miles bac.
I always understood sm 465 were all the same now I found there were at least two types, up to 1972 there was a mount on the bell housing.
73 and up had a rear crossmember mount at the end of the trans.
This is the transmission I have.
When I noticed the leak I ran out and bought a beautiful sm 465 300.00 with a clutch and disk.
I thought that was a good deal however yesterday pondering how I was going to remove and replace that 175 lb monster
I observed there were no rear mount on my replacement transmission.(old style)
But looking at the rear part of the trans it looks like i could swap the casting on the end of the trans thus assembling the old style sm465 with the bolt on rear from the new style .
So I guess my question is can I convert the transmission to a new style by swaping out the casting by putting the tew stylre back end with the trans mount in the casting on to the old style transmission.
Is this feasible to do or is it complicated.
I would love to hear comments on this subject.
If this is already covered in detail please direct me to the post
