codfish
Drive a hybrid. I NEED your gas!!
- Jun 9, 2022
- Newfoundland
- gary
- K10
Newly rebuilt trans has about 500 miles on it, give or take. Trouble free.
Took the truck to town today. After an hour or so of running around to different places, the truck was hard to start. Seemed flooded. Once it started had to rev it up somewhat to clear the “flood”, so it would stay running. Engine ran fine.
Idled across the parking lot, to the road home. Noticed the trans felt weird. Not shifting. Felt like it was slipping!
Limped it to a safe place to get out for a look. Popped the hood and went to the dip stick. Right on the mark. Not hot and smelled fine.
Checked the tv cable. Still connected and adjusted to the same tension as when I installed it, as per the paint mark I put on the cable once I adjusted it. HOWEVER, when I pulled the cable from the housing (mimicking the throttle pulling it when you press the pedal), it didn’t pull itself back into the transmission as quickly as it normally would. Tried it a few more times and it seemed fine. I closed the hood and proceeded to drive it, and everything seemed fine again. Shifting fine, no slipping sensation,etc.
One thing to note also, when it started acting up, I tried to shift it manually , and nothing. Stayed in whatever gear it was in.
Ideas???
Codfish
Ideas???
Codfish
