annoying rattles
muleys86
East Tennessee
Doug
C10 Scottsdale
hello all, on my 86 Scottsdale I have a rattle in the parking brake assembly, worse than a can of marbles. Anyone have this issue and how did you fix it?
Any help is greatly appreciated. Muley
Maybe some of the e-brake return springs (in the drums and on the cables) are broken/weak - or more likely, the actuating cables are not free to move in their sheathing. Or it may be that the equalizer needs to be adjusted. Another frequent failure point is the connector between the equalizer and the front common cable. Or the tensioning spring where the common cable passes through the LH forward cab mount. It could simply be that the pedal assembly is damaged.
But, whatever the problem is, you are there - so you'll need to be the one to first determine at least the general area. And, then someone can help you fix it. IOW try to be more specific and also provide some history. For example, it would be helpful if we knew what you have already attempted to repair and whether the e-brake is currently functioning .
Here's the thing, the foot pedal assembly is dependent on the actuating cables being intact and the various springs being taut enough to keep the pedal from bouncing around. If that is even what you are talking about - I am only guessing. When you reef down on the pedal, the springs/cables are tensioned and that kind of locks the mechanism in place. And - if everything is working as designed - even when you reach down and pop the handle there is still sufficient tension to prevent the pedal and operator from moving.
Here are a few things to look at:
muleys86
East Tennessee
Doug
C10 Scottsdale
e brake
chengny, the rattle is definitely at the foot pedal assy under the dash is the culprit. Havent had a chance to look at it, cant twist my large frame (gut) under the dash to see. It sounds as if a rubber bushing or bumper is missing.
Gonna be installing shocks soon so I"ll check it out. I just thought maybe somebody had this issue too. Thank you for your help. Muley
muleys86
East Tennessee
Doug
C10 Scottsdale
e brake rattle
After looking at the pic of the parking brake assembly, maybe I should remove it to check closer at the problem. Any precautions needed before this is attempted? Maybe tension on the cables or ??? Guys, I appreciate any ideas
Muley
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
I have a similar problem. It was bad when I had a serious vibration coming from my rear brakes. Turns out the three mounting bolts for the pedal assembly are loose. One of these days I'll get around to tightening them up.
Image and text from the 1986 Service Manual:
And some photos:
I couldn't find a picture of the bolt - that holds the frame to the side wall. But I'm sure you'll figure it out.
Just removed an e-brake assembly recently - took about 10 minutes.
CRM
Pasco, Washington
Casey
K2500
350 CI
While we're on the subject of parking brakes....Is there a way to adjust the pedal to set the brake before it goes all the way to the floor like mine does?
E-brake adjustment for 1977 C/K:
muleys86
East Tennessee
Doug
C10 Scottsdale
My lucky day! The e brake pedal assy has a bolt that was loose. My brother tightened it up and no more rattle. Happy day! Muley
tnahaus
