ambitious
skidmark62
r kansas
mark
just bought a beat up 90 single cab flatbed 3500 simply to harvest the 454 that resides in it...transmission I'm assuming is a TH400 to go with it. Looking at an 86 reg cab swb 4 X 4 with tranny issues. my "ambitious" project would be to join the two together in holy matrimony and spend countless and unobtainable dollars on it. Big block SWB 4 X 4 may just tickle my fancy? Hope to learn more from the square body masses as time goes on...
Camar068
Air Force Supporting Member
10 yrs Air Force
if your 90 is 4x4 and has an NP205 in it, you might want to hold on to it. Hard to come by and it's cheaper to mate the 6 speed auto 6L80 tranny to it.
skidmark62
r kansas
mark
no it's a 2wd unfortunately but already i'm paying attention...if I hear what you're sayin, I need to keep my eyes peeled for an NP205 and a 6L80 tranny to bolt up to the 454 and all this should fit effortlessly into the 86 swb?
not sure what motor/trans/transfer case is in the 86 but do know it's a 1/2 ton
NP205 is: a) preferred for durability, b) standard in a 3500, or c) standard bolt-up with a 6L80 tranny?
Camar068
10 yrs Air Force
not easy at all. You'll need to do some research. I'm going through an LS swap but wish I had an engine w/6l80 to put in. If I had an NP205 circle pattern, I would be one step closer and would pursue it. Funds are stopping me.
a - yes
b - some came with it
c - $120 adapter from Advanced Adapters, yes an NP 205 with CIRCLE BOLT PATTERN will bolt up to a 6L80.
Moderator Administrator
Welcome aboard GMSB Mark. You know in High School, there was this kid we called Skidmark. Of course he earned the name cuz he **** his pants in class. You didn't live in Cali as a kid did you? You're close to my age sooo..... Just making sure that isn't you.
skidmark62
r kansas
mark
coulda been...I did a little time in cali...1978...samohi!
:happy175: Naww, wasn't you. I'm from the Norwalk, Downey, Santa Fe Springs area.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Welcome to the board!
1ATony
Tony
K1500
Welcome to the site
Tony
dan86
