Aluminum 16.5 modification
Hoodless
Willet
Chad
k20 c10
Can an aluminum 16.5 be turned down to a 16?
Sent from my SAMSUNG-SM-N910A using Tapatalk
87scotty
Central il
Andrew
V20
5.7 for now
Well its not .5 inch thick may be able to work it but itd probably cost more than buying 16s
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Unless you're running solid wheels, I'd assume it's not possible. You'd have to remove atleast 0.25" all the way around plus machine a correct bead for the tires.
Too much material would be removed for it to still be considered safe. Cheaper and safer to just find a set of 16's.
Hoodless
Willet
Chad
k20 c10
Was worth a thought
wilson79
