Coop8202
- Sep 26, 2024
- Charleston, WV
- Austin
- K30
Hello all. 1976 K30. Intermittent starting issues. New battery, newer alternator. Starts perfectly after sitting for weeks, starts consecutively cold and hot. Pulled into gas station, off for 5 minutes or so. Almost like battery was shot, barely cranked. Volts reading below 13V on dash. Checked output from alternator next day, read normal. Volts on dash between 13V-15V, but when using multimeter and doing load test, getting between .7-.9 voltage drop at alternator and alternator bracket. Assuming this may an issue with grounding and not the alternator intermittently charging or starting to go?
