Alternator charging too much?
RustyBuckets
Kansas City
Jake
Hey, so ive got an 85 k10 with a 79 350 and i replaced my battery which i feel died prematurely with a new one and i noticed it seemed to be boiling over the battery acid. So I checked the idle voltage and its charging at 14.9v. It seems a bit high but do i need a new alternator?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Probably just the voltage regulator. A bit cheaper then a new alternator
15V? Yeah, I think that’s too high. If you have an alternator shop near you, have them put in a new regulator. $25 where I’m from for parts and labor.
hatzie
k20
14.5v is the normal good charge voltage. Is your meter accurate? 0.4v may be in tolerance for some cheaper meters.
Does the voltage rise higher when you open the throttle or stay stable?
If not I'd try another meter or two before condemning the alternator.
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
13.8 - 14.2 is spec for that alternator.. 14.5 is just barely below boiling.. Why buy a complete alternator when a new voltage regulator will take care of it.. Good advice @hatzie
4WDKC
Southern Florida
Kacy
If you have any plans in the future for electric fans, winch. stereo system something else that draws a low of power you may want to upgrade the alt to a higher amp.
wilson79
