after market ac system
That's pretty sweet. Looks like factory venting. It looks as if the A/C box venting for under the dash mounts separate from the existing heat/defrost system ducting.
I love how the controls are built into the left vent, that is pretty trick. That is a fairly good price too. Looks like a project to install.
I am guessing yiu would uave to cut holes in the dash for the vents? I never saw a non factory ac dash cover, I don't kniw if the holes are there already and covered with tril or not.
To be able to look at the installation instructions fir this kit would answer a lot of questions.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Some non A/C trucks had dash vents and but most did not. The right two can be added by replacing the trim as the dash and pad already have provisions for the vents, the glove box is A/C specific as well. And of course the gauge bezel can be replaced with one that has the vents. It's very difficult to add factory A/C as the cabs are different.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
On mine anyway, they aren't there. I guess you could get a dash over that is made for a/c and make it work easy enough. But cutting up a non-a/c dash cover is a losing battle.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
if is has the vents in the dash tim, it is 100% a factory AC dash cover, regardless of what the truck has. all dashes have the AC vent holes, just non-AC trucks have a trim piece without the vents cut into it. there are no trucks without AC with heater ducts exiting through the face of the dash pad.
RetroC10Sport
Jay
pontiac aztek
That's hilarious...Our family had a 1978 Silverado with dash vents but no A/C and I found 3 trucks in salvage auctions this week with dash vents and no A/C.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Makes sense. You may not have needed a/c, but want to be able to put in on VENT and let in fresh air from outside.
matthew1985
ga
matthew
My truck has factory air with all the vent holes and everything but for some reason the previous owner snatched all the ac stuff off everything does anybody kno where I can find a complete own system
I was able to fix the glove box, here a pin fell out for the latch. I just used a cotter pin and stuck it in there. Works fine now, fuggit...
:shitsweak:
attachment.php
attachment.php
attachment.php
attachment.php
I also had to adjust the striker out a little to make it shut nice without slamming it, it is adjustable.
attachment.php
attachment.php
attachment.php
RetroC10Sport
Jay
pontiac aztek
You might have to scrounge junkyards and look on Craigslist and just get all the pieces one by one. A new evaporator, accumulator, compressor, lines and condenser would be best anyway. Then you would just need - depending on what you are missing - A/C box, under dash pieces, any missing brackets, cables, HVAC controls
CaliDude76
NorCal
Sal
Nineteen Eighty Four
C-Ten (Custom Deluxe)
Three Fifty
*waits patiently for the write up on this :popcorn:
Oh ****, I accidentally hijacked a thread, I am a dumb ass. :sad72:
dan86
