Advice 94, Z-71, 1/2 ton Rear Diff locker install
Curt
Loco Hills
Curt
K-30
I have the Ten bolt Rear and for sure has No locker now----Just want to be able to put some type of locker in and know axle spline without having to take axle out??? Have to order it anyways after I see what one works best from all you guys,,
All rear 10 bolts I know of are 30 spline.It’s only the front 10 bolt that is 28 spline.
Front 10 bolts are 28 spline from 77’ to 89’ I believe,then 30 spline after.
However,if you’re going so far to add a locker,might as well refurb the bearings,seals and brakes.(take a look at least).And before you take my word on what YOU got,nothing will beat your own eyes.
Durfman77
Michigan
Charles
GMC
How do you know this? It would be helpful if you posted a pic of the sticker in the glove box.
heres photo of numbers;;
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Well, that confirms what you already knew...no traction-aiding option on it. I looked into the Z71 package a little more and it was basically just skid plates, Bilstein shocks, and a sticker. The gear ratio was usually, but not always, the GT4 3.73. As suspected, the G80 was a separate line item which seems strange for a truck with an "offroad package."
Durfman77
Michigan
Charles
GMC
Would this be ok option? A New G80 from Amazon for $279?,,,,
GM 8.5" Posi Unit - 30 Spline - Chevy GMC - Eaton-Style Limited-Slip Locker NEW
Would Full synthetic oil be ok in this? Or if I go with Lunch-box type would same oil be ok?? Thinking 85w-140?
Durfman77
Michigan
Charles
GMC
Hello--I been reading and reading and reading up on all these and am more confused than ever? I had a stock-G80 in a 2000 two wheel drive for years and it worked ok--So i found what looks like a good clean not used much on e-bay for $175 with shipping came out a 99 GMC Yukon Denali with bearings --What you think on this route? I have stock tires and just live in country gravel roads and pull a trailer about 3 times a week all summer with 4000lb [mowing]
Nonstop
Ca
Nick
K2500
Honestly, heard good reviews about Eaton True Trac. I would not go back with a gov lock. I run a Detroit Locker and love it, but it can be a little quirky and tires tend to wear faster. We replaced plenty of gov locks when I worked in a shop. I like saving money, but I would not want to risk blowing my rear end up, especially when towing a trailer.
Curt
Loco Hills
Curt
K-30
Eaton makes sound products.I would stay away from the gov lock period.
I say buy the best you can afford on a traction adder.I second not liking the idea of rear axle failure.
that_orange_c10
