actuator rod to ignition switch
mbl530
new york
michael
350 ci 375 hp
im switching a non-tilt steering column to a tilt steering column, the non tilt is a 75, and the tilt is from a 77. the actuator rod for the tilt column, from what im reading wont fit in the 75 ignition switch, so I will be buying an ignition switch for a tilt column. if my info is correct, please reply. thank you.
73c20jim
Tombstone, AZ
FenderBanger
