AC Swap over
Moderator Administrator
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
What a matta? 2/70 A/C aint good enough? :crazy:
:roflbow:
It's hot as hell in the midwest. I'm driving my 24 valve and letting the burb sit just for the AC. Even though the gas mileage is 4-5 mpg better in the burb. It's been about 107 in Wichita.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Wow...I like a little more meat on my .......cat haha. That helps some. This should be fun lol :rofl:
Yeah, a little more than that, maybe taller too.
Hopefully between the few threads and members you won't have any trouble with an AC coversion. Best part is, it'll be OEM not aftermarket.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
this is how i handled converting my firewall to an ac firewall
this truck also had some weird aftermarket ac in it
i cut the red part out of a ac suburban
if you cut a peice from a donor cut it big and use the holes that match up to line it up. then use self tapping screws to hold it in place (i screwed on the edge of my trim line so i could weld the scew holes shut) then trim it to fit.
you can see some of my screw holes in the pic
That the perfect way to do it. This way you know it's in the exact spot as OEM. I never thought about it, but I guess I should cut that out of my burnt cab truck incase someone needs that metal for a conversion. That truck also has perfect rockers and floor pans I figured I'd cut out of it too. What better sheet metal to replace with, than OEM sheet metal instead of aftermarket that's cut where they decide it should be cut, and sometimes not enough.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
ya but if the metal was burnt it is no good it will be week a fire changes sheet metal alot
I'm aware of that. This is why the cab is scrap. The firewall, and the front clip is what's burnt and warped. It was actualy an engine fire. The floor pans, rockers and cab corners are still just fine. I believe the metal behind the AC box is spared by the box itself.
Ooohhhhhhh, and there's some pics of some skinny ***** in that thread too !!! :naughty:
lmao...
Good advice and pic man. :grd:
usar17
PA
K20 Silverado
TBI350/700r4/NP208
i dont think we are talking ac anymore :Big Laugh:
But ya that cut and paste theory is genius. Thanks guys
oneluckypops
Sedalia, Mo.
Luke
And I'm the mod here, so to set a good example, I NEVER take threads off-topic. Must have been 89S's fault. I guess I'll follow behind him lke usual and clean up his mess.
Addition: Should be all good now Shawn. I moved the "fun" to the off-topic thread.
http://www.gmsquarebody.com/forum/showthread.php?p=97462#post97462
oh **** it i will derail it now lol.
Hotrod you just love following behind 89s, it gets you off errrrr i mean it gives you great pleasure :Moon:
Gurn
