AC blows out bottom instead of vents
Pappys84
Killen,Al
Johnny
C-10
84 Chevy C10-been sitting up a while. Slowly cleaning and checking out systems. When set to AC , very weak air comes out the vents but the bottom floor vent blows much stronger. It does this with ac, max and the bi-level setting. Didn’t notice air out defrost. Any suggestions.
PS: truck had set up several years and rats had nested in engine compartment-some damage to wiring but i didn’t see any chewed completely apart.
gmbellew
Kansas city
glen
suburban 1500
search on hvac. there are a couple of threads that show pics of the clip that frequently breaks on the blend door and the connector rod between the two main blend doors. the glove box and the vertical duct piece need to come out and from there you should be able to see what you have.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The other possibility is the vacuum switch on the back of the A/C control head, and the hose that feeds the vacuum to the servo.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Like Matt said. That's exactly what mine did when the vaccum line on the firewall to the blower box broke.
FenderBanger
