A/C System Help!!!
jfkelley
Oklahoma City
have an 1976 K10 Scottsdale 4X4, The A/C has been retrofitted it blows Semi Cold when Idling , But if I give it gas while sitting still the blower speeds up and blows cold, Also when you drive it you can hear it start blowing harder and its gets cold..A/C has been charged , All Ducts been inspected and are good..Do I need a new Clutch fan or Blower Motor ? Maybe one out of an 1994 Truck?..Plus the A/C Blows Max regardless what setting you have it on...Its HOT in Oklahoma Everyday way over in the 100’s today...Any Help or Advice would help ...Thanks !
Moderator Administrator
Sounds like you might have more of a voltage issue. If the blower speeds up when you rev the engine, your voltage may be dropping at idle. By retrofit, do you mean converted to R134A freon? That might be part of the problem too. From what I hear, the R134a requires a higher pressure and maybe the compessor isn't putting that higher pressure out at lower rpms.
What rpm are you idling at? Auto or manual trans? Maybe bump the idle up a 100-200rpm for the summer. If you're at 500 rpm now, 700 won't be to bad.
Colin
Covington, GA
Colin
K10 Silverado
350 cu. in.
Make sure the condensor isn't obstructed with dirt, etc. and is able to flow fresh air across the fins.
jfkelley
Oklahoma City
I have an 1976 K10 Scottsdale 4X4, The A/C has been retrofitted it blows Semi Cold when Idling , But if I give it gas while sitting still the blower speeds up and blows cold, Also when you drive it you can hear it start blowing harder and its gets colder..A/C has been charged , All Ducts been inspected and are good..Do I need a new Clutch fan or Blower Motor ? Maybe one out of an 1994 Truck?..Plus the A/C Blows Max regardless what setting you have it on low medium ..Its HOT in Oklahoma right now 118 today...Any Help or Advice would help ...Thanks !
dvdswan
Port Orchard, WA
Dave
To test your fan clutch, engine off, cold, and depending what the temp is outside (i.e. below 40* or above 100* the fan should turn with good resistance). Engine off and the engine is warmed up and 118* outside the fan should not turn at all.
Yes, that too.
Rusty Nail
Cowboy of both Time and Space
Russell
350sbc
My thought substituted VACUUM for Hotrod's voltage issue. Increased engine speed reduces available inches of travel? Some ****. Is it blowing equally side to side or?
$525+or- to fix mine. That's the bar cuz I was seein about mine yesterday. :(
How much YOU got to spend? lol? Hot AF! :flamingdevil:
jfkelley
Oklahoma City
Thanks for all the replies ..No Baseball tourney this weekend , So I will try everyone suggestions & report back my findings
jfkelley
Oklahoma City
Yes sir I was meaning R134A
jfkelley
Oklahoma City
I took a video of the AC Compressor with A/C going Belt flopping around
1st pic is at Idle with A/C on
2nd Pic is driving with A/C on
jfkelley
Oklahoma City
Please check your grounds as well including the battery posts. Bad ones can cause those symptoms
Check all the grounds I could find and cleaned them with wire brush and reinstalled and no change in AC ..Do I need a Bigger Alternator ?
bajadiver
