96’ Vortec carb in 86gmc fuel pump question.
trapper70
maine
trevor
k1500
Hi everyone, I installed an 1996 Vortec 5.7l in my 86’ GMC and am using a carburetor which is working out great. There is no provision for mechanical fuel pump so I am running an electric puralator 3-7 psi pump located near the tank.
I am changing out the tank due to an old repair leaking and am wondering if a pump in the tank is a possibility?
Are the pump mounting flanges for like the 88’ on up the same as a sending unit flange on the top of the tank for 87’ down.
If so is there an in tank pump with the 3-7 psi or will need to run a pressure regulator?
TIA
Moderator
The tank openings are the same, however, the FI tanks have a "cake pan" tray made into them to help keep the pump submerged when the tank level is low.
I'm not sure if a direct fit, low pressure pump is available or not. Personally, I'd run a TBI pump and a bypass regulator. That pretty much eliminates the chances of vapor lock.
Smtty58
Mass.
Lyle
R3500 Crewcab
I did a little research on this for mine. So far I have been unable to find a bypass regulator that can take the 16 psi TBI pressure down to something a carb can handle. Looks like most of the regulators are for high pressure EFI systems.
Moderator
Moderator
Moderator
I read somewhere that can only handle 12 psi input pressure. If that's wrong, then yes, that will work.
I've never heard that before. I know they normally get used with higher pressure pumps and it works fine. Out of curiosity, I looked through the questions that have been asked on Summit about the regulator that I linked. It says this:
Smtty58
Mass.
Lyle
R3500 Crewcab
Thanks Bucket!
You have to take into account the size if your return line it needs to large enough the eventually it cannot bypass any more fuel. If/when it cannot bypass anymore fuel then pressures start to climb. I haven't had any trouble on TBI or other injection with pressures under 45psi. I did have a problem with a 98 chevy vortec. The factory bypass line was too small, it became a restriction and ramped up the fuel pressure.. also if your block has the mounting pad for a fuel pump just no pushrod provision. You can mount a factory pump and use factory lines for clean plumbing up front I'd try using g a factory pump as my bypass keep drilling the restrictor larger until you are bypassing enough fuel.
Arkansas C10
