trapper70
- Nov 22, 2024
- maine
- trevor
- k1500
Hi everyone, I installed an 1996 Vortec 5.7l in my 86’ GMC and am using a carburetor which is working out great. There is no provision for mechanical fuel pump so I am running an electric puralator 3-7 psi pump located near the tank.
I am changing out the tank due to an old repair leaking and am wondering if a pump in the tank is a possibility?
Are the pump mounting flanges for like the 88’ on up the same as a sending unit flange on the top of the tank for 87’ down.
If so is there an in tank pump with the 3-7 psi or will need to run a pressure regulator?
TIA
TIA
