91 V1500 suburban
rumblebox
Victoria, TX
Carlton
I jumped the oil pressure switch and replaced the fuel pump to get it running and drive it around the property, but it sat another 6 months, and the fuel pump won't come on again, although there wasn't a bit of rust in the gas tank.
New alternator and belt
It didn't have any brake fluid in it when i got it, and i broke a bleeder off the right caliper and haven't had time to change it. The parking brake cable also broke when i was driving it.... That was scary.
4wd works, and trans shifts fine as far as i could tell.
No rear glass. Gate latch doesn't work. Some of the window motors don't work very well.
Leaks trans fluid at either the cooler or a line up front
The quarter panels are rusted, but the floor is decent. Looks like it spent some time at the beach.
It has some kind of suspension lift. The 32 11.50 15's on front look fine. It has 35's on the rear that are in pretty bad shape and shouldnt be taken on the highway.
It comes with but not installed:
· thrush chambered muffler (straight-piped now)
· high-flow magnaflow cat(still has stock cat)
· plugs/wires/cap/rotor
· oil pressure switch
$2000.
Sent from my LG-H910 using Tapatalk
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
This has a lot of potential. I hope it goes to a good home.
83K5guy
Corpus
Justin
K5 Blazer
Did this ever sell
Sent from my SAMSUNG-SM-J320A using Tapatalk
83K5guy
Corpus
Justin
K5 Blazer
$2000.
Hey rumblebox did you ever sell the suburban or crew cab, Im about 30mins away and interested in either preferably the suburban
rumblebox
Victoria, TX
Carlton
The crew cab is gone, but i have 2 suburbans i need to sell.
Dale Downes
