91 suburban axle swap
BOX918578
Michigan
Demetreus
C10-suburban
I have a 91 suburban 4x4 and when I got the front axle is 6 lug and the rear is 8 lug is there a way to change the rear without taking the whole rearend out
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Change the front. Leave that rear end alone, you’ll just have to get 8 lug hubs for the front axle
BOX918578
Michigan
Demetreus
C10-suburban
thats what I thought but someone told me the gears would kill my trans? Just trying to make the best choice
BOX918578
Michigan
Demetreus
C10-suburban
And is the hub the only thing I need to change
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
yevgenievich
Place
Name
Year
Model
Size
Verify gearing front/rear. Then depending on budget and desired results, either proceed with hub/gear change in the front or offer the rear up for a trade and make couple hundred dollars by putting it back to stock.
4WDKC
Southern Florida
Kacy
check the gears int both and decide which ones are better for you then swap out the undesired gear/axle for one with the right ratio/hubs.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Also is this a half ton or 3/4 ton? Personally I would keep the FF it probably has a lower gear ratio in it, which may be what you want. Depends what you’re doing with it, all you need to make sure you do is match the gear ratios between the two axles. If the ratio is different, even a little bit then yes, you will hurt drivetrain components.
1. Make sure gear ratios are the same in each axle
2. Get a new hub
3. Might have to swap yokes(might not either)
Furr
