90-91 Trip/Speedo in an 85
Doppleganger
OH-MI: Just like it sounds
Is the 90-91 speedos with the tripometer a direct swap into an older (85) cluster? Really wanted something aftermarket (better) gauge wise but $ may not allow it for a bit. Was wondering because I thought the electronic trans came in around then and wondered if the speedo was cable or VSS driven.
THX
nvrenuf
Mobile, Al.
90 and 91 models had an electric speedo using a VSS sensor on either the trans (2wd) or tcase (4wd). I believe the circuit runs through the computer plus you'd need a DRAC, etc. I would not think that would be an easy install.
BKING33
York Springs, PA
K30, Suburban
6.2, 6.2 turbo
Yes you can do it. It will require some wiring upgrades. I installed a 90 Speedo in my 89 Burb cluster.
All you have to do is wire it up to a DRAC module and of course you need the wiring to the vehicle speed sensor.
ak4life
alaskan born, fed and bred.....lol.
nevada
chris
81/84 gmc, 2001gmc, 2003 gmc, 2005 chevy
longbed squarebody, longbed 4dr extended cab, yukon sle, 4dr ext. cab
383, 6.0, 5.3, 5.3
Anyway you can elaborate, sorry i get what you are saying.....but can you list all parts involved regarding lets say an 81 4wd k20 w/700r4 and adding an 1989 gauge cluster and steering column.....pics and instructions would be nice but i get thats not exactly an easy task....thanks in advance
BKING33
York Springs, PA
K30, Suburban
6.2, 6.2 turbo
You will need a Speedo from a 90 or 91 Blazer or Burb. I just swapped out the speedo from the existing cluster on my 89.
I spliced in the wiring from the drac module to the speedo. You will also need the harness that goes to the vehicle speed sensor as well.
I had a parts truck that I took everything out of that I needed. There are several different drac modules depending on your gear ratio and tire size.
i think they do make an aftermarket one that is adjustable.
There were '89 speedos with a Trip, and they were still cable drive. In other words, a direct swap.
CheemsK1500
K1500
I'd look into getting a digital conversion box for your original speedo like this one.:
It's a little pricey, but more versatile.
