90-91 np241 from a burb or blazer
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
As the title says, I'm looking for a np241 from a 90 or 91, I need it because it uses vss instead of a cable driven speedo.
Im looking to do a solid axle swap on my s10, and want to change drop sides to run 1/2 ton axles instead of retubing a 1/2 ton to fit the s10....
Let me know if you have something, I'll pay price + shipping, but remember, if you ship, it must be 100% clear of all fluids or the postal service will get upset.
Sent from my SM-G965U using Tapatalk
SquareRoot
Why not run a 205? I had my 205 modded for a vss by ORD. Best of both worlds.
Vbb199
Salisbury NC
Vince
Only because finding a 205 that will bolt up to the 4l60e could be a hassle, maybe not.
Do you have any knowledge on modding a cable driven t case to work with a electrical speedometer?
Could you share your knowledge?
Message me
A 205 and adapter from behind a th350 will bolt up to an early (4bolt tail) 4L60e with a simple spacer and a minor trimming of the output shaft.
The 208 and 241 really aren't a bad case. They are reasonably strong, lightweight, have a deeper low range than a 205, and the factory shifter is very user friendly compared to a factory 205 shifter.
Vbb199
Salisbury NC
Vince
Was kinda my thought... I'm not running a 500+ HP truck here.
When the 4.3 quits Ill swap a 5.3 or 6L in, and we'll see if we can make that 500 HP, but for now, my 250 shouldn't kill a np208 with 4.56 gears behind and in front of it.
I just want to go back to trail riding. I miss that.
Edit: Ive killed 1 np208, behind a 6.2, low range, big tires. Lol
SquareRoot
My Dakota Digital dash came with this adapter. Unscrew cable and screw this on.
They also have an inline adapter that gives you a vss signal and retains the mechanical cable.
I wished id known this before I had my 205 tailpiece modified. Now I'm putting in a GV overdrive and I'll be damned if it's adapter doesn't also have a vss output. So there's 3 ways to accomplish your goal. $37, $150 or $3000. Lol
Vbb199
Salisbury NC
Vince
I discovered Dakota digital last night as well
I contacted them about a solution
ak4life
alaskan born, fed and bred.....lol.
nevada
chris
81/84 gmc, 2001gmc, 2003 gmc, 2005 chevy
longbed squarebody, longbed 4dr extended cab, yukon sle, 4dr ext. cab
383, 6.0, 5.3, 5.3
Message me
I second that...
Vbb199
Salisbury NC
Vince
I ended up running a drivers drop ford Dana 60 kingpin with a 4L60e and a np241c with a custom clocking ring from a gmt400 in my rig.
Stickman
